Dust on the lens...
Discussion in 'Photography Beginners' Forum' started by padrepaul77, Oct 12, 2009.
  1. padrepaul77
    padrepaul77 TPF Noob!
    Jan 28, 2009
    155
    Twin Cities, MN
    I'm sure this is pretty common, but just wondering how you handle it? Not the lens glass up front, but when you change the lens, on the small back part of it. I was changing the lenses to go wide angle, and a tiny speck of dust fell on the back side of the lense that attaches to the body. (Not sure of the excact name for this other than the expensive part of the lens). I gently blew to try to remove it, but it remained, so just gently took my lens cloth and removed it and all seems fine; no problem with the lens and images are good. I just don't want to cause damage...any suggestions?
    Thanks,
    Paul
  2. silentfallen
    silentfallen TPF Noob!
    Dec 7, 2008
    51
    Medicine Hat, AB
  3. dhilberg
    dhilberg TPF Noob!
    Jul 26, 2008
    516
    Washougal, WA
    Are you talking about the rear lens element? You can clean this the same as you would clean the front element. I use a Giottos Rocket Air Blower for dust. Use hot breath and a microfiber cloth for stubborn dust particles and smudges. I wouldn't blow on it with your mouth though, you might accidentally spit on it, which complicates cleaning.
  4. fiveoboy01
    fiveoboy01 TPF Noob!
    Dec 28, 2008
    684
    Waunakee, WI
    A blower to get the particle off, if it's stubborn I use a lens pen.
  5. Plato
    Plato TPF Noob!
    Jul 11, 2009
    1,058
    United States of America
    I used "canned air." Works great for front and back glass on lenses but do NOT use it for the sensor filter.
  6. Buckster
    Buckster Been spending a lot of time on here!
    Sep 14, 2009
    6,399
    2,334
    Way up North in Michigan
    Rocket blaster here.
