DX 70-300 compared to DX 55-300
Discussion in 'Nikon Lenses' started by fotkar, Nov 25, 2017.
  1. fotkar
    fotkar TPF Noob!
    Nov 10, 2017
    15
    I am buying a tele lens and I cannot choose between
    Nikon JAA829DA P DX Nikkor 70-300 mm 1: 4.5 – 6,3g Ed Vr
    and
    Nikon AF-S DX Nikkor 55-300 mm 1:4,5-5,6G ED VR
    The later is 1/3 cheaper.
    I will also take a D7500 with 18-140 kit.
    What is the difference between the 300 lenses? WHich one I should take?
  2. jaomul
    jaomul Been spending a lot of time on here!
    Feb 4, 2011
    5,414
    1,414
    Cork Ireland
    The newer 70-300 is supposed to be the better performance lens. By all accounts the 55-300 is a nice imager but very slow to focus
    • Agree Agree x 1
  3. fmw
    fmw No longer a newbie, moving up!
    Sep 30, 2006
    3,656
    471
    The smaller the zoom range, the better the image quality, all other things being equal.
    • Disagree Disagree x 1
  4. Braineack
    Braineack Been spending a lot of time on here!
    Jun 17, 2013
    11,224
    4,335
    NoVA
    Emphasis on very.
    • Agree Agree x 2
  5. fotkar
    fotkar TPF Noob!
    Nov 10, 2017
    15
    tnx. I just went ahead and bought:
    D7500 with kit 18-140
    dx 35mm f/1,8
    Nikon DX Nikkor 70-300 mm 1: 4.5 – 6,3g Ed Vr
    Now I think I am well setup for my new photo adventures!
    :1219:
    • Winner Winner x 1
  6. jaomul
    Feb 4, 2011
    5,414
    1,414
    Cork Ireland
    Very well set up. Enjoy
  7. nerwin
    nerwin Been spending a lot of time on here!
    Jan 31, 2015
    3,133
    1,046
    Vermont
    Great setup, you'll love it! The D7500 is a solid performer. You won't have to upgrade for a long time.
  8. fotkar
    fotkar TPF Noob!
    Nov 10, 2017
    15
    I received the gear and I am playing a bit for the last day or two.
    Amazing camera!
    I just have one slight issue with 70-300. I was not testing it a lot but I have a feeling that the smallest focal length 70mm is a bit too much. I have a feeling that I would be better off with 55-300 as I have a feeling this difference of 15mm at the bottom end is making a huge difference.
    Can you comfort me that in situation where I will be using this lens this difference will not be so important?
    Or should I contemplate sending it back and getting 55-300?
  9. Braineack
    Jun 17, 2013
    11,224
    4,335
    NoVA
    might as well go buy that 18-400mm and get rid of all your other lenses.
    use your 18-140 if you need less than 70mm.
    the 55-300 is a pretty junk lens.
  10. astroNikon
    astroNikon 'ya all Bananas I tell 'ya Supporting Member
    Aug 15, 2013
    13,209
    3,211
    SE Michigan
    Truthfully I find the 70-300, the 70 to be too much on a DX camera too if the subjects are too close. I use a 70-300 on my FX camera for the short end and long end. On a DX the short end is more 105ish FOV which is restrictive. In that regards the 55-300 is better. But the 55-300 lens falls short in many areas compared to the 70-300 especially the newer 70-300 AF-P lenses.
    But you have a 18-140. For more close up subjects consider using that lens instead.
    Some people migrate towards quality glass (multiple lenses) while others towards one-all convenience. For instance there is a 18-300 DX & 28-300 FX too which are great for convenience. There's also a Tamron 18-400. but as mentioned the 55-300 is a poor quality lens all around.
    You'll have to figure out which end of the spectrum you prefer.
  11. nerwin
    Jan 31, 2015
    3,133
    1,046
    Vermont
    When I was shooting crop, I never noticed the difference between 55mm and 70mm when I upgraded from the 55-200 VR to the 70-300 VR, it's not THAT much of a difference. Just take a step back if you need to. It wasn't a big deal. I just can't see missing 15mm causes you miss so many shots.
    If it is, then perhaps you should look into getting an all in one zoom, like the 18-400 Tamron, or the 18-140 Nikon kit or something of the like.
    Like @astroNikon said, you have to figure out which end of the spectrum you prefer.
    Personally, I like the restrictions because it makes me think more and forces me to use what I have and be creative.
    Just my two cents. You can't have it all. There is no 10mm-1000mm f/0.95 VR VIII that fits in your pocket and weighs less than your phone.
    • Agree Agree x 1
  12. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    40,028
    15,012
    USA
    I must disagree with this; to a HUGE extent, what determines zoom lens quality is NOT the zoom range--it is the initial retail price point AND the generation of the lens. The above quoted statement and its reference to zoom range being the key quality determinant is outdated thinking, and ignores the simple fact that _modern_ zoom lenses, ones that are designed to be used on high-resolution digital SLR's these days, can be extremely good performers, and the HIGHER the initial retail price, and the more quality emphasis the maker put into the lens, the better the lens will perform--even with a wide zoom range.
    A low-end lens like an 18-55 kit zoom, one that retails for $99 as part of a kit is quite often only average at f/4.5 to f/5.6, which is near wide-open, or totally wide-open...yet a $999 to $1,500 zoom with a 5x focal length ratio can easily better a $99 lens. Same thing with _MODERN_ high-dollar lenses like the 28-300 from Nikon: QUITE a good lens...or the 200-500 Nikkor zoom...or the NEW 80-400 AF-S. All these are good lenses; the new 80-300 VASTLY outperformes the old one ( the one I made thousands of great pictures with back in the 4- to 10 megapixel era) because it is 1)much newer than the earlier 80-400 and 2)It was DESIGNED and priced to be a good zoom.
    The old-days advice of "high zoom ratio = "crap lens" is not valid, as far as it goes. One must take into consderation the quality and price point that the maker designed the lens to be built for! As well as the design ERA...old-time lenses with regular glass, no aspherical elements, NO nano-crystal coating, etc,etc,no VR, and low price are often not all that hot on today's digital cameras..
    Here is a GEAT example of an on-line review that shows the 28-300mm Nikkor VR zoom is a FINE lens...Nikon 28-300mm VR Review
    Why? Because of everything I mentioned above; NEW-era design...HIGH priced, multiple ED glass elements, multiple aspherical elements...built to be GOOD, for NEW-era digital capture.
