editing question
Discussion in 'Photography Beginners' Forum' started by royalWITHcheese2, Nov 8, 2007.
  1. royalWITHcheese2
    royalWITHcheese2 TPF Noob!
    Nov 8, 2007
    140
    Mass
    I haven't done too much editing in the time that i've been into photography, but I do know that when I do edit, I shouldn't leave the file type as a JPEG. My question is should I edit the JPEG and save the changes as a TIFF, or should I import the pictures, re-save as a TIFF, and then start editing?
  2. Sweetsomedays
    Sweetsomedays TPF Noob!
    Jun 24, 2007
    788
    San Diego, CA
    I shoot RAW, edit as RAW, save the raw image and a JPEG copy.
  3. Sideburns
    Sideburns TPF Noob!
    Aug 14, 2007
    2,796
    Windsor, Ontario
    there's no point in converting from jpeg to tiff. If the pictures are already jpeg..do the editing in jpeg. If you shoot in RAW...then you can edit in RAW or TIFF...but otherwise theres' no point.
  4. DHammer
    DHammer TPF Noob!
    Aug 22, 2007
    82
    Only advantage to saving it as anything but a jpg is if you save it as a psd. And then only if you have added layers or done something that you can come back to tweak if needed. Other than that best option shoot RAW edit save as a copy to jpg.
  5. nossie
    nossie TPF Noob!
    Oct 15, 2007
    794
    Dublin, Ireland
    Sideburns I think you should convert to TIFF when editing or more usually a PSD (photoshop file). JPEG is a lossy format meaning that every time you make a save you will lose some more data from the image.
    I would suggest you use jpeg only as a "release" format.
  6. (Ghastly) Krueger
    (Ghastly) Krueger TPF Noob!
    Feb 20, 2006
    1,393
    Lost between tomorrow and yesterday
    I agree with nossie. If you are going to edit only once, it's ok to save to jpg, if you will adeit and save several times, you should use something other than jpg.
