ef v ef-s
Discussion in 'Photography Beginners' Forum' started by rhinoryan, Jan 27, 2010.
  1. rhinoryan
    rhinoryan TPF Noob!
    Aug 17, 2009
    94
    Gold Coast, Australia
    i have a ef-s 300mm lens and i want a bit more zoom.... if i get a ef 300mm on my 40d will i be able to get in closer?
  2. icassell
    icassell No longer a newbie, moving up!
    Jun 7, 2008
    9,898
    11
    Arizona
    EF is the Canon mount that can be used on all of their digital cameras -- full frame and crop sensor
    EF-S are specifically made for crop-sensor cameras and will vignette significantly on the full frame cameras.
    At the same 300mm focal length on your crop sensor 40D, the image size will be the same (e.g. no additional zoom) with EF or EF-S. If you want more reach on your zoom, you must go to a longer focal length zoom (e.g. 100-400 or longer) or prime (e.g. 400mm f/5.6) or use a teleconverter (which 300mm do you own? I didn't think Canon made an EF-S 300mm prime). Not all lenses are compatible with teleconverters.
  3. Village Idiot
    Mar 20, 2008
    7,274
    406
    No. EF and EF-S just designate the lens mount. Most APS-C Canon cameras can use EF and EF-S mount lenses with the exception of some of the really old cameras. The Canon APS-H and Full Frame cameras can only use EF mount.
    It's not the mount that determines the FOV of a lens, it's the sensor.
  4. KmH
    Apr 9, 2009
    40,066
    5,452
    Iowa
    No.
    300 mm is 300 mm unless you switch from a crop sensor to full size.
    EF/EF-S is just the mount. Well, actually the mount is the same. The diameter of the part of the lens that goes in the camera body is different.
    EF-S lenses can't be used on EF bodies but EF lenses can be used on EF-S bodies. (Or, is it the other way around? :lol:)
  5. Village Idiot
    Mar 20, 2008
    7,274
    406
    EF-S lenses won't even mount without modification. They'll end up contacting internal camera parts if you try to mount them.
  6. Village Idiot
    Mar 20, 2008
    7,274
    406
    Depth maybe? Diameter measures the width of a circle. The back portion of an EF-S lens fits deeper into the body vs. an EF lens,
  7. NateWagner
    NateWagner TPF Noob!
    Jun 2, 2008
    1,240
    St. Petersburg, FL
    Actually 300mm is 300mm no matter what. It's the effective FOV that changes.
  8. icassell
    Jun 7, 2008
    9,898
    11
    Arizona
    :thumbup:
  9. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
  10. Big Mike
    Dec 16, 2003
    33,864
    1,822
    Edmonton
    That was the first thing I thought when I read this thread.
    So if the OP has a 300mm EF-S lens...he had better hold onto it...it must be rare. :er: :lol:
  11. fokker
    fokker No longer a newbie, moving up!
    Jun 23, 2009
    2,830
    294
    New Zealand
    Maybe he is referring to a 70-300 zoom, but is only interested in the long end? Also, village idiot; in some cases EF-S lenses will fit fine on a body with EF mount though only in some cases, and it's not really recommended to try as I understand.
  12. Village Idiot
    Mar 20, 2008
    7,274
    406
    Last time I heard some one trying this, their focus screen popped out.
