Effect of film camera body on final image quality
Discussion in 'Photography Equipment & Products' started by aaronseymour, May 4, 2005.
  1. aaronseymour
    aaronseymour TPF Noob!
    May 4, 2005
    Hello. This might be a stupid question but how much does the body of the camera impact on the final quality of photos taken? Other their any other factors than quality of exposure system? Is it better to buy a cheaper body and invest in more expensive lenses?
    thanks,
  2. westman
    westman TPF Noob!
    May 7, 2004
    341
    body deosen't affect the quility very much (except it got a lot of dust in it)
    but lens' quility (optical) does affect also the films (format of the films , quility of films..) . other thing is the way you develop the films , do you use good quility equiments to develop and the technies..
    of coz , if u got money buy a better body , the functions and performences are much better than the cheaper one . if you don't have much money , u can just forget this..
    i think spend on good lens is nice , actually lens does affect the image very very much .
  3. ferny
    ferny TPF Noob!
    Aug 31, 2004
    8,114
    64
    A camera body just holds the film and operates the shutter and aperture. If you've got a lens and two camera bodies to fit it, one worth £100 and one worth £1000, you won't notice any difference in the quality of the final image if the same settings are used.
    There is a difference between the two bodies though. The more expensive one will probably be stronger and have more features (faster shutter speeds and other things). That's why there is a huge second hand market in photography. The body makes very little difference.
    The lens is what makes the difference (as westman said, there are other issues but I'll ignore them). The light which creates your image passes through the lens, not the body. You want that light to reach the negative or sensor of your camera with as few alterations to it as possible. That's why the more expensive lenses will normally give you a better picture. They're a far higher quality. That isn't to say it is always the case and that doesn't mean all photographs taken with a cheap lens aren't any good. Far from it.
    If you've got the choice between a second hand body in good condition and a brand new start of the art one I'd go for the second hand one. Ok, you won't have all the features but in normal photography you'll never use half of them. And you'll have more money to spend on your lens/lenses.
  4. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    Probably, but it's a very general question, and there are a lot of variables.
    What cameras are you looking at?
    What is your planned subject matter?
  5. deb
    deb TPF Noob!
    Jul 7, 2004
    219
    East Tennessee
    To some extent, the body can (not necessarily does) affect the images. If the body allows light to enter, you will get the "holga" effect (which has its own merit, but more as a novelty than as a standard). If you choose a second hand body, you may want to have a camera shop clean it and check the seals just to be certain there are no light leaks or dust to ruin your pictures.
  6. Walt
    Walt TPF Noob!
    Feb 12, 2004
    1,054
    BC
    As mentioned repeatedly above the lense is more important. That doesn't mean the cheapest camera available is ok. The camera should have a good, consistant light meter and shutter. It takes a bit of research but some cameras may be better than others at keeping the film perfectly flat. Also make sure the body does the minimum of what your need are, ie: pc socket for studio lights, depth of field preview, mirror lock up etc.
does camera body affect image quality
does the camera affect your film photo
how does camera body affect images
how does the camera film affect the quality of a picture
