Efke roll film
Discussion in 'Film Discussion and Q & A' started by selmerdave, Aug 24, 2007.
  1. selmerdave
    selmerdave TPF Noob!
    Nov 30, 2004
    454
    Brooklyn, NY
    I got a couple of rolls of Efke 25 120 film back the other day, and while the photos turned out great they show signs of light leaks at the sides of the film. Considering I had the seals replaced on my Yashica not long ago and have had no issues of leaks with any other film, I think these leaks must have come from the spools. What do I need to do, wrap them in tinfoil when I take them out? Anyone else use it and can verify whether they had the same problem?
    Dave
  2. Jeff Canes
    Jeff Canes No longer a newbie, moving up!
    May 19, 2003
    6,192
    22
    Hollywood, FLA USA
    Did you have them rolled tight? Are there any leak patterns? I used Efke a lot never noticed leaks to be common.
  3. selmerdave
    Nov 30, 2004
    454
    Brooklyn, NY
    I'll see if I can get an example to come out in a scan. They were rolled as tight as any other roll film, and at the time had no reason to think there would be any problem but when both came back (and actually each was processed a few days apart) with the problem while the roll of EPP in between came back fine, I figured it must be the spool. Good to hear you haven't had the same problem, I have a couple more rolls so perhaps I can avoid it happening with them and continue to use it, as I said I like the (photographic) results.
    Dave
