Electric Generators
Discussion in 'Photography Equipment & Products' started by upliftmofo, Dec 14, 2008.
  1. upliftmofo
    upliftmofo TPF Noob!
    Dec 14, 2008
    Edmonton
    Does anybody have any recommendations for a small portable generator that could run a couple 300ws heads?
  2. Pure
    Pure TPF Noob!
    Oct 22, 2008
    420
    You know this is going to hella loud? They are loud as hell, unless you put them far far away, or it doesnt matter.
  3. table1349
    table1349 Been spending a lot of time on here!
    Sep 9, 2006
    4
  4. RyanLilly
    RyanLilly No longer a newbie, moving up!
    Aug 27, 2007
    1,478
    8
    St. Louis, Missouri, USofA
    on small gas generators, they are all pretty similar, they are all loud. One with a Briggs and Stratton or Honda engine are pretty good, all small engines have a life of about 2000 hours, most engines can be rebuilt, however there are some honda OHC engines that are not rebuildable, the OHV models typically are rebiuldable, but That could have changed. That is all prettymuch a moot point if you cannot rebuild it yourself, otherwise its cheaper to buy a new one. Get one that has an easy regulator adjustment so you can compensate for voltage drop if you use long runs of cable to keep the generator at a quieter distance. Always meter power at the end of your cable run before you plug anything into it.
  5. JustAnEngineer
    JustAnEngineer TPF Noob!
    Apr 11, 2008
    609
    Heart of Dixie
  6. Village Idiot
    Mar 20, 2008
    7,274
    406
  7. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    If you are going to use a generator, you may need to clean the power before using it for your strobes. I believe it's a Pure Sine Wave Inverter that you would need.
  8. jlykins
    jlykins TPF Noob!
    Dec 1, 2007
    1,235
    Cincinnati
    For the same price as the generator if not less, you could do the Vagabond system and it would be a whole heck of a lot quieter.
  9. notelliot
    notelliot TPF Noob!
    Nov 13, 2005
    827
    people are mentioning the V2 powepack - which is hands down the way to go.. if you're using bees or white lighting monolights. but, if you're using a flash head that feeds off of a powerpack (like profoto 7b - which are something like 2000w/s) a generator would be the way to go.
    since you're asking about generators, the honda line isn't really that loud at all, and are very reliable. I mean, if you're out in public firing off strobes with 3 or 4 people around you, chances are that you'll draw quite a bit of attention anyway hah. you'll need to get a permit to use it though - not actually to have it running, but because of the space you'll be taking up with your lights, cords, etc.
  10. Village Idiot
    Mar 20, 2008
    7,274
    406
    The V2 works with more than Alien Bees and White Lightings and I did mention made for monolights. The V2 has been tested with Elinchrom digital monolights and would probably work with pretty much any monolight out there. Of course, bigger lights get less shots, but a claimed 1200 pops at full power with the B800 is pretty good.
  11. table1349
    Sep 9, 2006
    4
    You mean something like this.
    http://www.profoto-usa.com/products/pro-7/pro7b.asp
    I shall repeat myself then: "Clean electricity, quiet, affordable, environmentally and model friendly."
    Anybody actually dragging flash heads and power bricks around really ought to look into either alternative power as posted above or monolights and something like the V2. Flash head, stands, multiple cables, power brick(s), generator, gas, lots of extension cords etc. do not make for a convienient shoot.
  12. benhasajeep
    benhasajeep No longer a newbie, moving up!
    May 4, 2006
    4,021
    494
    The Honda generators are not loud at all! Even some of the chinese knock offs are well under 60db now. You can have a normal conversation standing right next to it, and not be bothered by it at all! Honda's also puts out stable power. Well under 3% (electronics safe). This is where the knock offs differ. They are upwards of 5-6%. Honda makes a 1,000 watt version that is quiet, compact, and fairly light. But you pay for it. Also a 2000 watt, and bigger 3000 watt in the really quiet ones. Yamaha also makes I think a 1,200 watt one that has similar numbers to the small honda. And then there is lots of copy cats. But the quality differs on them
    I have 2 knock off ones. They both start on first pull, quiet and the first one dependable for 3 years even though only occasional use. Not as quiet as a Honda, but can be right next to it with no problem. Just got the second one.
generator photography
photography generator
