Elinchrom BXRI 500 & pocket wizard
Discussion in 'Lighting and Hardware' started by Raincheck, Aug 17, 2013.
  1. Raincheck
    Raincheck No longer a newbie, moving up!
    Jun 23, 2011
    222
    98
    Dublin, Ireland
    Hi forum,
    Today I got my Elinchrom BXRI 500 kit:
    2x BXRI 500
    1X EL-Skyport speed
    2x Portalite softbox
    2x lightstand
    1x Rotalux strip light
    Also a new lens Canon EF 180mm f/3.5 L Macro USM
    Okay here we go, I also have 2x 580EXII speedlites + 2x FlexTT5 and 1x Mini TT1
    After some research the best way I think is to buy 2x PW PowerST4 for the BXRI 500 to work with the PW.
    After buying the above I am broke and have to wait until I am able to get the PowerST4's
    I am now using the MiniTT1 on my Canon 5DII transmitting to a FlexTT5 with a EL-Skyport speed on top
    Using my second FlexTT5 for a 580EXII that works!
    Why, using the EL-Skyport speed on top of the camera doesn't really work loads of miss fires with the BXRI 500 at random.
    Maybe I am doing something wrong?
    One thing I don't understand is the speed sync mode:
    I set the EL-Skyport speed by holding the test button down for 5 seconds until it flashes 2 times
    Then set BXRI 500 to r.2 mode
    Set the camera to 1/250 - now I have a dark bottom border on my shots
    Any forum members having the BXRI 500's working with speeds 1/250 or higher only using the EL-Skyport speed?
    Grtx Rick
  2. tirediron
    Jul 8, 2005
    38,194
    11,086
    Victoria, BC
    I can't help you with the Skyport system, but it occurs to me that the misfires could simply be a result of 'stacking' your triggers.
    • Like Like x 1
  3. gryphonslair99
    gryphonslair99 Been spending a lot of time on here!
    Sep 9, 2006
    12,148
    2,234
    Wichita, Kansas, USA
    Max sync speed for a 5D MkII is 1/200th of a second.
  4. Derrel
    Derrel Mr. Rain Cloud
    Top Poster Of Month
    Jul 23, 2009
    36,842
    13,525
    USA
    And using "some" triggering systems, many users find that the stated maximum speed of 1/200 second is still too fast, and they must drop a little bit more speed to get full, 100 percent flash synchronization across the entire 24x36mm sensor area. It is harder to sync fast across a FF sensor than with a smaller sensor.
    Good luck with it. And congratulations of the new 1800mm Canon macro--wow, what a fine optic!
  5. gryphonslair99
    Sep 9, 2006
    12,148
    2,234
    Gee, I didn't know that canon made an 1800mm Macro lens or any 1800mm lens. :mrgreen:
  6. Derrel
    Top Poster Of Month
    Jul 23, 2009
    36,842
    13,525
    USA
    Ooopsie!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Guess I put one too many zeros on there!
  7. gryphonslair99
    Sep 9, 2006
    12,148
    2,234
    Darn, I was hoping that Canon had a new lens I could get.
  8. Tee
    Tee Been spending a lot of time on here!
    Mar 26, 2010
    1,941
    607
    The burbs of Philly
    You don't need to stack both triggers on your camera. If you want to use your speedlights in conjunction, use the MiniTT and set your monolights to slave. Problem solved. That's what I did when I used that combo. I've never had a misfire using my Skyports and I'm suspecting, based on the information you've posted, you're not allowing enough recycle time to occur. Keep in mind, if you are looking at stopping really quick motion, you need to upgrade to the Ranger line. On the BXri 500's, you can freeze basic motion such as jumping and things like that (just watch for hand and feet movement). With that being said, you can find tutorials on the web using work arounds to get higher speed sync but it takes practice. What is it that you're trying to capture at high speed?
  9. Raincheck
    Jun 23, 2011
    222
    98
    Dublin, Ireland
    Hi Guys,
    Thanks for the replies, I was sure I did nothing wrong but still using the el-skyport speed only I have a 90% miss fire rate. Setting them to slave same thing even firing the flash with the test button on the back of the flash doesn't always work. So I brought them back and see what happens.
  10. Village Idiot
    Mar 20, 2008
    7,274
    406
    The PW Hyper Sync option can let you shoot at about 1/250 on a 5D MKII with little to no banding.
bxri hypersync
camranger pocketwizard painting with light
do you need a pocketwizard to fire elinchrom bx 250 ri
elinchrom brx 500 pocketwizard
elinchrom brx 500 pocketwizard high speed
elinchrom brx 500 with pocket wizard flex tt5
elinchrom miss firing
pocket wizard elinchrom brx500
set up elinchrom brx 500 with canon 5d mk 3 tutorials
why my bxri 500 misfires
