EMERGENCY!
Discussion in 'Digital Discussion & Q&A' started by AlexColeman, Mar 8, 2009.
  1. AlexColeman
    AlexColeman TPF Noob!
    Dec 13, 2008
    1,732
    My hard-drive a western digital 320 my book (black) is failing to mount on my macbook pro. It is 10.5.6, and it won't mount on the desk top. When I run Disk Utility, it says
    Invalid node structure
    Volume check failed.
    Error: Filesystem verify or repair failed.
    Any help is appreciated.
  2. gryphonslair99
    gryphonslair99 Been spending a lot of time on here!
    Sep 9, 2006
    12,055
    2,221
    Wichita, Kansas, USA
  3. AlexColeman
    Dec 13, 2008
    1,732
    I have tried everything, won't mount. I am really aggravated as it won't work, because it has my LR catalog on it.
  4. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    As a matter of interest bring up a console and type fsck which is a unix package to check file systems. If it comes up then it may be called the same thing in MacOSX in which case this package is a good place to start since it can repair broken Inodes.
    But maybe a mac user can give you something better to go on.
  5. Slaphead
    Slaphead TPF Noob!
    Apr 28, 2008
    399
    Zürich, Switzerland
    Good idea, but unfortunately it won't get you anywhere in this situation - FSCK is run by the disk utility and has already reported that it can't repair the volume (Error: Filesystem verify or repair failed.). This message indicates that FSCK doesn't think it can repair the volume (at least in my experience - which is a lot)
    The tool that I run to in this event is (actually in any disk problem) is DiskWarrior
    I've had amazing success getting back data with this tool - even when drives are on the brink of complete hardware failure.
    I SERIOUSLY recommend that you buy another hard disk so that when Diskwarrior has done it's stuff you can preview the repair and copy your data to it. Do NOT attempt to replace the disks directory with the rebuilt directory without copying the data first - if the disk is failing then this can turn a recoverable situation into a total loss.
    As ever with data recovery your mileage may vary, and if diskwarrior can't do anything (I've not come across anything yet that's worked when diskwarrior hasn't) then realistically you'll need to send your disk to a professional data recovery outfit.
    Hope this helps and good luck.
  6. flea77
    flea77 No longer a newbie, moving up!
    Feb 6, 2009
    593
    34
    Huntsville, TX
    This kind of stuff is what I do all day, every day, and SlapHead has it right on. Quit messing with it, leave it off until you are ready to do the recovery. Run it as little as possible to get what you need, then replace it.
    Allan
  7. AlexColeman
    Dec 13, 2008
    1,732
    I have been trying to use DW, however it gives me an error.
  8. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Rule 1 when talking about errors is "State the bloody error"
  9. Slaphead
    Slaphead TPF Noob!
    Apr 28, 2008
    399
    Zürich, Switzerland
    Yeah, as Garbz said, we need to know what the error is.
  10. AlexColeman
    Dec 13, 2008
    1,732
    Error 2158. Thank you.
  11. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    :banghead:
  12. Slaphead
    Slaphead TPF Noob!
    Apr 28, 2008
    399
    Zürich, Switzerland
    OK, try this - Hold the option (alt) key down and click on rebuild. This should now throw up another window. Select "Scavenge" and then click on rebuild. This could take a while.
    By the way was there any error description associated with the that error code? I've had "similar" codes (2155) which indicate things are very bad but I've never experienced a 2158.
    If the scavenge doesn't work then I think you have to decide if the data is worth sending the drive to a professional data recovery firm.
(2155,-36) diskwarrior
disk warrior 2155
disk warrior 2159, -108
disk warrior error 2155
disk warrior error code 2155, -36
diskwarrior error (2155, -57)
diskwarrior error 2155
diskwarrior error 2155,-36
diskwarrior error code 2155
diskwarrior fail 2155, 60
