Emulsion Lifts
Discussion in 'Alternative Techniques & Photo Gallery' started by photoguy01, Oct 22, 2004.
  1. photoguy01
    photoguy01 TPF Noob!
    Sep 21, 2004
    10
    Florida
    Can anyone tell me the exact process for emulsion lifts??
    Thanks :?:
  2. Corry
    Corry Flirtacious and Bodacious Supporting Member
    Feb 5, 2004
    21,168
    109
    North Central Illinois
    I'm sure Auntie Terri will be in here shortly to explain it for you! :)
  3. Karalee
    Karalee hOtLiPs!
    Feb 22, 2004
    3,849
    47
    Here....there....everywhere
  4. terri
    terri Administrator Staff Member Supporting Member
    Sep 2, 2003
    26,380
    2,484
    In the mental ward of this forum
    I love the Polaroid site, too. :D But I really don't care for these abbreviated how-to's, I find something technically incorrect with all of them, it seems. :wink:
    In this case, it blows my mind that they say "tap water" when their own consultants, when quoted or consulted by alternative process writers, always say to use distilled water. Everyone's tap water contains varying degrees of ph, we commonly don't go about testing it, either. So as a rule it is advised to just use distilled water, with a neutral ph and no minerals or acidity.
    So that's my immediate two cents. :wink:
    Hi photoguy, the rest of the basic procedure is fine as outlined by Polaroid, but if you haven't already, check out all the "emulsion" threads here in this forum for more tips and techniques. Any specific questions you have that aren't answered here, just fire away!!!
  5. Ambrosia
    Ambrosia TPF Noob!
    Sep 23, 2004
    67
    Tampa, FL
  6. terri
    Sep 2, 2003
    26,380
    2,484
    I used tap water too, at first. It doesn't give any problems as far as ease of technique. I think it's a long-term issue concerning eventual discoloration of the emulsion. :wink:
  7. Karalee
    Karalee hOtLiPs!
    Feb 22, 2004
    3,849
    47
    :-? I didnt know that bout tap water - weve got a soft water filtration system, d'ya think that would make it worse?
  8. terri
    Sep 2, 2003
    26,380
    2,484
    You're simply trying to use water that has a neutral ph. That's why a jug of distilled water is the best solution. I've read about how to test your tap water's ph level, I believe it was using Litmus paper (??) and how to correct it, either too high or too low, to bring it into a neutral area. Too much work for me when I'm trying to be creative. :wink: And with a jug of distilled water available for a buck, why not be on the safe side? I use it for the vinegar bath solution for my transfers, too. Part of the reason for the vinegar bath is to restore ph to the dyes, since the act of prematurely separating the film disrupts it. It's important for long term stability of the image.
    I pretty much just use it for all things Polaroid. :p
  9. Karalee
    Karalee hOtLiPs!
    Feb 22, 2004
    3,849
    47
    Right on, thanks Terri, Im gonna get some distilled water before I do any more ;)
  10. terri
    Sep 2, 2003
    26,380
    2,484
    Yeah, do some soon and post 'em, Kara, your last one of the bridge was way cool. :D
  11. photoguy01
    Sep 21, 2004
    10
    Florida
    When I pot the polarioid in the water(160 degrees) the photo starts to separate, but the front picture(the part that is on the plastic front which has all of the color) stays on the plastic but separates from the emulsion, so when i can finallly peel off the emulsion it is a washed out almost whits peicture... does anyone know what im doing wrong??
    If someone can please send me pictures of the process... :?
  12. Karalee
    Karalee hOtLiPs!
    Feb 22, 2004
    3,849
    47
    What kind of film are you using?
what type of film to use for emulsion lifts
