EN-EL3e Battery drained out.
Discussion in 'Nikon Cameras' started by BrianLy, Aug 22, 2011.
  1. BrianLy
    BrianLy TPF Noob!
    Jun 3, 2010
    298
    Los Angeles
    Yesterday I fully charged both of my Nikon EN-EL3e batteries and this morning I was using it fine, and I just got home and both of them are completely drain? What could be the problem. One of them is only a few months old. It was both in my D200 with the MB-200 grip. I left it on "ON" but I always did and this never happened before. I have a third party charger that was given to me when I bought my D200 from Adorama. It worked fine before.
  2. aliancer
    aliancer TPF Noob!
    Aug 22, 2011
    26
    North Sydney
    Practically speaking, if you shoot from fully charged, it would go for 400 raw shutter before you got the 30% left, and 600 non-continously shutter. The vertical grip would not give any drain possibly unless it's 3rd party product. The main problems are either the feature of the lens (af, vr, etc) and the how often you're using the preview screen.
    Even it's fully charged on your charger, don't forget to check the battery status on your camera as well, and check how's the performance after the first 100 shutter (raw) or 250 (jpeg) from the fully charged. If it's above 75%, it's still quite normal...
    Sent from my iPad using PhotoForum
    • Like Like x 1
  3. joealcantar
    joealcantar TPF Noob!
    Apr 23, 2011
    840
    84
    Beaumont, CA
    Label the batteries and label the chargers so you can tell how it was charged etc. , and do your testing to see if it is a certain combination.
    shoot well, Joe
  4. IgsEMT
    IgsEMT No longer a newbie, moving up!
    Jul 27, 2009
    2,694
    49
    NYC
    Shooting RAW eats more juice and as joe said, label them.
    By the way...
    If you're using 3rd party batteries, that could be an issue. My Nikon batteries still last me after 3 yrs, my 3rd party - crappy garbage :)
  5. BrianLy
    BrianLy TPF Noob!
    Jun 3, 2010
    298
    Los Angeles
    I shoot in jpeg fine, it was fully charge when I left and got home they were drained dead.
  6. ghache
    ghache No longer a newbie, moving up!
    Jan 25, 2010
    3,570
    295
    your grip could be the problem. I know that d200 is pretty bad on battery life but if you didnt use the camera they shoulnt have drained out of power.
  7. BrianLy
    BrianLy TPF Noob!
    Jun 3, 2010
    298
    Los Angeles
    This was the first time, but it hasn't happen since.
  8. paul85224
    paul85224 TPF Noob!
    Sep 11, 2011
    224
    28
    The D200 battery has a history of draining much quicker than Nikon's estimates. I purposely won't leave the camera on at all to conserve battery life and typically take a spare body as backup.
  9. Overread
    May 1, 2008
    23,823
    4,084
    UK - England
    Did you use the popup flash more than normal? That will certainly put a bigger drain on the batteries if you did use it.
  10. BrianLy
    BrianLy TPF Noob!
    Jun 3, 2010
    298
    Los Angeles
    I either don't use flash or if I do I use my SB600. But it hasn't happen to be again, it was just that one time.
  11. fotomanjack
    fotomanjack TPF Noob!
    Oct 15, 2011
    60
    Calgary, Alberta, Canada
    What firmware version do you have on your camera? It should be 4.01. This version "solved" a bit of the battery drain problem inherent to the D200. Also, third party batteries aren't micro chipped like the Nikon batteries are. Ask me how I know. :) As stated by others, leaving the camera on for an extended period, using the view screen constantly.......will drain the batteries. Also, third party chargers are not wired like the Nikon chargers. They ARE different, even though they work the same.
    I have learned over the years to take out my batteries from the grip when not using the camera for a week or more.
  12. rgregory1965
    rgregory1965 No longer a newbie, moving up!
    Aug 15, 2011
    711
    84
    arizona
    Someone used your camera when you werent home......
en el3 battery wont charge
en-el3e battery dead to revive
nikon en el3e battery dead
nikon en-el3e battery problem
