Enlarger Bulbs
Discussion in 'The Darkroom' started by Parker, Apr 12, 2007.
  1. Parker
    Parker TPF Noob!
    Apr 12, 2007
    Hi,
    I recently purchased a Jessops 3500 B&W Enlarger off ebay that didn't come with a bulb and have since found out that they have discontinued their production. So I'm stuck with an enlarger minus the all important light source!
    I just wondered if anyone knew:
    A) Anywhere that I could get hold of a new Jessops 3500 Enlarger bulb?
    B) If there was any 'makeshift' type bulb I could use in the absence of the correct one.
    It has a standard Edison Screw 27 fitting (220v - 240v, 100w max)
    Hope someone can help
    Thanks,
    Parker
  2. Steph
    Steph No longer a newbie, moving up!
    Oct 18, 2006
    1,314
    Steventon, Oxfordshire, UK
    Have a look here. They have a small selection of enlarger bulbs. Hope that helps.
  3. Parker
    Parker TPF Noob!
    Apr 12, 2007
    Hey, thanks for the link. Unfortunatley I have already looked there and I think the bulb I need is the one that says
    "The Following Lamps are at present un-available due to manufacturing difficulties"
    However, even though my enlarger says MAX 100w, I'm tempted to try the 150w bulb on that site. Is this a mildly, or seriously stupid idea?
  4. Steph
    Oct 18, 2006
    1,314
    It might not be very safe to use a 150W bulb. I am not sure.
    Alternative links (they don't mention availability):
    - Morrisphoto
    - Lamps-on-line
    Alternatively, you can use any white bulb that fit and that does not have any writing on the glass.
  5. Flash Harry
    Flash Harry No longer a newbie, moving up!
    Jun 26, 2006
    1,966
    14
    Durham, UK
    take the enlarger head apart and modify the electrics to take the normal type 2 pin bulbs it should only mean disconnecting the old light fitting and refit a two pin holder.
  6. Hertz van Rental
    Hertz van Rental We're supposed to post photos?
    Nov 8, 2004
    16,738
    46
    Where am I now?
    If it is a standard ES fitting then there are quite a few bulb manufacturers you can turn to. Best thing to do is find a photo store with a darkroom section and ask if they have a bulb. They usually carry spares.
    Using one of a higher Wattage is a bad idea as the head will not lose the heat fast enough. When it gets hot, lots of baaad things can happen. You are OK using a bulb of lower Wattage - you will just have to expose your prints for a bit longer.
    Try here (US): http://www.freestylephoto.biz/tl_techtips_det.php?id=3&p=2
    If you are in the UK just go to Jessops.
enlarger bulb darkroom
jessops 3500 enlarger 120 film
