Enlarger help needed!
Discussion in 'The Darkroom' started by ian1987, Jan 22, 2007.
  1. ian1987
    ian1987 TPF Noob!
    Jan 16, 2006
    34
    Madrid
    Hi!
    i bought a while ago a very basic BW enlarger (condenser type), and it came with no light bulb in it. i tried the first bulb I found around the house (a 60W clear) and (obviously very dark, it was just a test) I saw the light wasn't properly spread in the projection of the light. I changed the bulb for a 75W diffused bulb and it looked a lot better, but still there is a slightly noticeable gradient of light at it's projection. Would moving up to a 100W bulb solve this? What bulb do you recommend? In the instruction manual it doesent specify the type of light bulb, it just says 100W maximum.
    please shed a bit of light :lol: to this issue.
    Thank you!
  2. Steph
    Steph No longer a newbie, moving up!
    Oct 18, 2006
    1,314
    Steventon, Oxfordshire, UK
    Sometimes you can get uneven lighting because of writings on the glass of the bulb. Bulbs designed for enlargers don't have any writings on them. Maybe you could try one of those to see if it makes a difference.
  3. ian1987
    ian1987 TPF Noob!
    Jan 16, 2006
    34
    Madrid
    i already thought about that, but the writing in the bulb is on the top, so the light that's going into the condenser isn't (at least that's what I think) not affected by the writing.
  4. Torus34
    Torus34 No longer a newbie, moving up!
    Jan 26, 2006
    2,117
    37
    Tottenville, Staten Island, NYC USA
    See if you can interpose a piece of opal glass between the bulb and the condensers/film.
  5. df3photo
    df3photo TPF Noob!
    Dec 31, 2004
    629
    Erie Pennsylvania
  6. ksmattfish
    Aug 25, 2003
    7,019
    34
    Lawrence, KS
  7. Majik Imaje
    Majik Imaje TPF Noob!
    Feb 15, 2007
    285
    Point Hope Alaska
    if it says 100 watt max then it can handle 100 watt lamps.
    I am not trying to be a smart arse at all, just putting it up as I can see .
    I am also wondering if you have the condenser set right ?
    have you tried to insert a negative and view it in the dark ?
    do you have the correct focal length lens?
    I have a lot of questions !
