Enlarging color negatives with B&W enlarger
Discussion in 'Film Discussion and Q & A' started by Brutus, Sep 1, 2010.
  1. Brutus
    Brutus TPF Noob!
    Aug 24, 2008
    216
    So I have some color negatives that I'd like to print, but I only have access to a B&W enlarger and grey scale photosensitive paper. Is there a way to enlarge and print the color negatives as if they were B&W successfully?
  2. compur
    compur No longer a newbie, moving up!
    Mar 6, 2008
    2,994
    497
    L.A.
    Kodak used to make a paper for just this purpose called Panalure but it was
    discontinued about 5 years ago. It does show up from time to time on eBay
    and, if not too old and if properly stored, that would be one solution.
    Otherwise, here are some tips from Ilford on using their MG IV paper for
    this purpose:
    ILFORD PHOTO - Printing from Colour Negatives
  3. djacobox372
    djacobox372 No longer a newbie, moving up!
    May 4, 2008
    2,925
    129
    Seattle, WA
    Try it and see what happens... it should work fine as along as you avoid variable contrast paper.
  4. oldmacman
    oldmacman TPF Noob!
    Jul 16, 2010
    1,597
    70
    Southern Ontario
    On regular BW paper the shots will be grainy. The layers of colour in the negative can act as contrast filters when you are exposing. You can still get some interesting effects. I'd definitely run test strips so you have an idea of what you'll be getting.
  5. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    yes
    and be prepared for longer printing times and issues with contrast. You will need to boost the contrast filter at least 3.5
    i have students who make lovely prints this way; as anything else in the darkroom it just takes patience and lots of practice.
  6. Brutus
    Brutus TPF Noob!
    Aug 24, 2008
    216
    Thanks for the responses. I'll have to try just adding a contrast filter and seeing what happens.
color negative enlarging
how to enlarge color film
