EOS 350D Question!
Discussion in 'Beyond the Basics' started by Tibi_N, Jun 21, 2005.
  1. Tibi_N
    Tibi_N TPF Noob!
    Jun 21, 2005
    10
    How does my 'Depth of Field Preview Button' help me?
    What exactly is it used for?
  2. mrsid99
    mrsid99 TPF Supporters Supporting Member
    Mar 8, 2003
    2,964
    5
    Florida
    The DOF preview button literally does that, it gives you a preview of the depth of field i.e how much of the scene is in focus.
    It does that by setting the aperture to that it will be when you press the shutter button.
    You probably know that DOF is inversely proportional to aperture size so as the aperture gets smaller (higher F numbers) the depth of field increases.
    Typically when you press the DOF button you'll notice that the scene gets darker and that's because the normal view is with the aperture wide open.
    Try setting the F stop to a reasonably high number (small aperture) and then pressing the DOF button, the first thing you notice is the scene gets darker but if you look carefully you'll see that more of the scene is now in focus.
    Have fun!
  3. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    Welcome to the forum.
    Do you know how the aperture of the lens works? And how aperture affects Depth of Field?
    The aperture is the hole through which light passes through the lens. It is adjustable and measured in F stops. A big F number (F22) is a smaller opening and a small F number (F2.8 ) is a bigger opening. The bigger the opening (small F number) the less DOF you will have. The smaller the opening (high F number), the more DOF you will have.
    When you are looking through your camera's viewfinder & lens...the aperture is always open as big as possible, to let in the most light. Because you are looking through the biggest opening, you are seeing the shallowest DOF...so things that may look out of focus in the view finder, may actually be in focus in the photo.
    The DOF preview button stops down the aperture in the lens so that you can see the actual DOF that the photo will have. Now the smaller the aperture is set to stop down, there will be less light that is coming through the lens...so the viewfinder will appear darker. Let your eye adjust to the darker image and closely inspect the areas that are in or out of focus. It takes getting used to.
    Of course with digital, you could simply take the photo and then look at the image on the screen to see the actual DOF.
    Hope this helped.
  4. Tibi_N
    Tibi_N TPF Noob!
    Jun 21, 2005
    10
    Thanks a lot guys!!!
    I'm beginning to 'see the light' ;)
    But, how do you obtain the maximum depth of field, on a regular basis, without any computer programs like DoF Master!? Is there an empiric rule?(or someting) ;)
    PS:sorry, if i'm being annoying!
  5. mrsid99
    Mar 8, 2003
    2,964
    5
    Florida
    There are cases when you want a minimum DOF such as some portrait work but remember that as F number increases (smaller aperture) the shutter has to be open longer to compensate.
    This means that it's a trade-off between DOF and shutter speed, if for instance you're shooting something moving and you want to stop motion then a fast shutter speed is called for and this will limit the F number you can go to...well that and film ISO but hopefully you see the connection.
  6. Tibi_N
    Tibi_N TPF Noob!
    Jun 21, 2005
    10
    I can see the connection ;)!! I'll try to be more specific!
    For example, when you're shooting a landscape (sunlight, iso 100, using a large F number F22 , F36, or somethin'), how can I make sure that I'm using the right aperture in order to obtain a greater depth of field, and where should I point the focus for that? I mean, is there a basic rule, or do I have to stick my eye in the viewfinder, press the dof preview button, and hope I'll see what is and isn't in focus!!! ;)
  7. mrsid99
    Mar 8, 2003
    2,964
    5
    Florida
    Well pressing the DOF preview button will give you an idea as to how much is in focus, I guess that's the reason for the button anyway.
    If you're just looking for maximum DOF for whatever reason, then go to the smallest aperture (highest F number) you can live with or the camera/lens can achieve because it's a direct relationship, smaller the aperture the greater the DOF.
  8. SLOShooter
    SLOShooter TPF Noob!
    Dec 21, 2004
    421
    I heard somewhere that you want to focus 1/3 of the way to the horizon and use the maximum f number that you can safely shoot. IE Go as high as you can without getting shake or blur from the long shutter speed. That will maximaze the in DOF. One thing to note though is that when you have some thing focused at infinity your DOF is essentially infinate.
    Now whether you want a long or short DOF is up to you as the artist.
  9. Tibi_N
    Tibi_N TPF Noob!
    Jun 21, 2005
    10
    Thanks again guys!! ;)
    I 've just read something about it in one of Jim Nachtwey's Articles and SLOShooter has really got it right!!! ;)
    Nachtwey says that when he is looking for greater depth of field he focuses at 1/3 of the desired image. :) He also says it really works;)
    You guys are really cool, you answer immediately and you definitely know what you're talking about!!! ;)
    Thank Again!!!
