Epson V770 scanner
Discussion in 'Film Discussion and Q & A' started by molested_cow, Mar 4, 2009.
  1. molested_cow
    molested_cow No longer a newbie, moving up!
    Jul 3, 2004
    3,645
    469
    Here N There
    I just bought the Epson V770 scanner... should have done this a long time ago.
    So as I was scanning negatives that I have, I noticed that the scans tend to be a little blur(unfocused) as compared to those that was done by the photo developer. Am I doing something wrong, or is there anything I can adjust to make this right?
    I compared scans with different settings but they don't seem to affect the sharpness of the image much.
  2. djacobox372
    djacobox372 No longer a newbie, moving up!
    May 4, 2008
    2,925
    129
    Seattle, WA
    I own a v700, which I assume is similar to the v770.
    It's VERY important to get the film carrier at the right height. There are little tabs on the carrier that allow you to adjust it up and down--there are three settings: no tabs, high tabs, and low tabs.
    Each scanner is different: with mine the high setting was better then the low but still not tack-sharp. So, I added three layers of masking tape to the bottom of each tab, and now it's perfect (as long as the film is flat, curled film is a hassle with this scanner).
    Also, consider that the lab doing the scanning for likely sharpens them a bit after scanning.
    good luck!
  3. molested_cow
    Jul 3, 2004
    3,645
    469
    Here N There
    So that's what the tabs are for! The instruction manual never explained what those things are.
  4. djacobox372
    May 4, 2008
    2,925
    129
    Seattle, WA
    Do three scans (no tabs, low tabs, and high tabs) and see which is most sharp. If the highest is most sharp, but still not perfect you may need to add a couple layers of tape to the bottom of the feet until you dial it in perfectly.
epson 770
epson 770 scanner
epson perfection v770
epson scanner 770
epson scanner v770
epson v770
epson v770 review
epson v770 scanner
scanner f4
v770 scanner
