error 99 - canon
Discussion in 'Beyond the Basics' started by Abstract, Jan 3, 2006.
  1. Abstract
    Abstract TPF Noob!
    Sep 11, 2005
    258
    UK
    I have started to get an error 99 message on my 350D when I try to use my sigma 400mm lens does anyone know what this error means and can I get it fixed? cheers for your help.
  2. Big Mike
    Dec 16, 2003
    33,838
    1,814
    Edmonton
    Does it happen all the time with that lens?
    If so, you might need to re-chip the lens. I think that Sigma may do this for little or no charge, or at least they used to.
    If it happens sporadically, it might be the electronic lens contacts. Give them a good cleaning (look it up).
  3. doenoe
    doenoe TPF Noob!
    Mar 4, 2005
    4,267
    23
    Hoorn, The Netherlands
    according to the manual:
    An error other than the one above occurred.
    Remove and re-install the battery.
    This error may occur if you use a non-Canon lens and the camera or lens does not operate properly as a result.
    Dont know how to fix that though
  4. pursuer
    pursuer TPF Noob!
    Aug 8, 2004
    1,397
    40
    Canada
    Error 99 is what your camera will give if none of its other error codes are appropriate, like a catch all statement, very none specific. However it seems to be a common issue with sigma lenses. Try googling "sigma error 99"
    Edit: It seems I neeed to be quicker with my posts, you guys beat me to it while I was typing :)
  5. Abstract
    Abstract TPF Noob!
    Sep 11, 2005
    258
    UK
    it started off occasionally but now is constant. Will contact sigma and see if they can fix it, thanks.
  6. Abstract
    Abstract TPF Noob!
    Sep 11, 2005
    258
    UK
    aparently it would need chipping but the chips are no longer available :(
  7. hot shot
    hot shot TPF Noob!
    Dec 29, 2005
    496
    ITs a nother no compatable lense but some times if you clean the contacts it will work if its desprate thats the only solution
    There was another company that chiped them at one point ill c if i can find them for you
  8. Abstract
    Abstract TPF Noob!
    Sep 11, 2005
    258
    UK
    thanks!!
canon d30 error 99
canon error 99 using a sigma lens
canon rebel xsi err99
canon tsi error 99
canon tsi error mesage
canon xsi error 99
error 99 canon rebel xsi
sigma error-99
troubleshoot sigma lens error 99 canon
what does error 99 mean on canon
