Existing Light
Discussion in 'General Gallery' started by Uncle Albert, Jul 27, 2005.
  1. Uncle Albert
    Uncle Albert TPF Noob!
    Jul 26, 2005
    28
    I'm working on taking outdoor pictures at night. This is a store down the street.
    [​IMG]
  2. spike5003
    spike5003 TPF Noob!
    Jan 5, 2005
    364
    Syracuse, NY
    i learned my lesson about night shots the hard way... so im not gonna tell you the secret :) im vindictive like that... However this is a good start
    heres a couple hints
    1) make sure your camera is on spot metering
    2) use bulb mode a tripod and a cable release
    3) the rest is up to you :)
  3. Uncle Albert
    Jul 26, 2005
    28
    Golly, I knew this was a good place to be. Can you really tell I handheld it using matrix metering?
  4. spike5003
    spike5003 TPF Noob!
    Jan 5, 2005
    364
    Syracuse, NY
    the lights are bright and the center is dark, that says matrix metering all over it... as for hand held if you were on a tripod you could use a longer shutter and the picture wouldnt be so dark....
    and cuz im a nice guy ill tell you how to do it
    in bulb mode your shutter stays open as long as you hold that cable release... now get a stopwatch cuz youre gonna need it for this
    Take an initial reading off the scene (make sure to spot meter off a dark part of the scene i usually go with something that is a little darker than the midtone but thats up to you)lets say for example it is f/4 at 1/15th of a second
    Now do the equivalent exposure to get that to f/22 or so (every time you move one f stop higher double the shutter time 1/15-1/8-1/4-1/2-1-2-4-8 etc.)
    that gives you a resulting exposure of f/22 at 2 second
    With anything over one second on a shutter speed you have to double it in order to avoid reciprocity failure... you dont need to know what it is just know that it screws up your shot and makes it too dark.
    so now you have f/22 at 4 seconds
    put the f stop on f/22 and put the camera in bulb mode
    Push and hold the cable release for 4 seconds
    use a stop watch and be as exact as possible... a few 10ths either way shouldnt matter much
    Do a few shots of each scene and try one at each 2 and 8 seconds just to make sure.... good luck
