thanks, yes they're a bit expensive but if they do the job then why not have one
i can use the flash meter with the expodish right??
yes but if i use the expodisk and a flash meter and adjust correctly than it should turn out??? i don't have any of these things here in kuwait yet, have to wait to have them shipped so its a little hard to figure out how they will all work out together
and from what i have read you are supposed to be able to use the expodisk instead of a gray card
One?
Don't they come in different sizes for different lenses?
Yep - "ExpoDisc filters are available with quick pressure release friction mounts (in standard sizes, including 52mm, 58mm, 62mm, 67mm, 72mm, 77mm, 82mm, 95mm,...)
And there are 2 versions - Portrait and Neutral
I would need 3 sizes of each version or 6 Expodisc's. No thanks!
