Exposure compensation/f-stop question
Discussion in 'Beyond the Basics' started by manicmike, Mar 23, 2010.
  1. manicmike
    manicmike No longer a newbie, moving up!
    Sep 29, 2009
    1,224
    307
    Oregon
    I'm not sure how basic this question is but what is the difference between setting your exposure compensation two stops underexposed and stopping down your f-stop by two stops?
  2. Garball
    Garball TPF Noob!
    Mar 17, 2010
    16
    Denver
    Just watch you settings as you compensate the two stops and you'll see you reach the same result. (assuming your on aperture priority)
    You shutter speed would have to remain constant in this example.
    g
  3. NateWagner
    NateWagner TPF Noob!
    Jun 2, 2008
    1,240
    St. Petersburg, FL
    It depends on what mode you are in.
    The main thing to realize is that exposure compensation is inherently a camera controlled aspect. It is the camera adjusting the shutter speed or the ISO to either under or over expose an image.
    So, if you are in shutter priority mode for example, and you use exposure compensation to knock it down to stops the camera will adjust the aperture down two stops.
    If you are in aperture priority and bump the Exposure compensation down two stops it will bump the shutter speed down two stops.
    Either way the exposure would be about the same (though obviously differences in either blur or DOF one way or the other).
  4. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    The more obvious difference is that adjusting any settings does not do any compensation to the camera's exposure meter.
    In Aperture priority if you stop down the aperture, then the shutter would decrease to bring the image back up.
    In Shutter priority if you speed up the shutter, the aperture would open up to bring the image back up.
    In Manual if you stop down the aperture the camera's exposure meter would tell you that you're under exposing.
    Dialling in exposure compensation biases this selection to change the ultimate brightness of the exposure meter in the camera. It will then purposely pick an aperture or shutter speed that darkens or brightens the image, and in manual mode it will tell you you're correctly exposing when you dial in the correctly adjusted settings.
  5. Hamtastic
    Hamtastic TPF Noob!
    Mar 9, 2010
    87
    USA
    Adjusting exposure compensation -2 tells the meter to expose 2 stops under middle gray (1/4th the light). Which of the 3 exposure controls (aperture, shutter, ISO) it uses depends on the exposure mode it's in.
    The effects of closing the aperture 2 stops also depends on the mode the camera is in. In M it would expose 2 stops under middle gray. In Av it would still expose for middle gray.
  6. PhotoXopher
    PhotoXopher TPF Noob!
    May 27, 2009
    3,475
    I typically use exposure compensation in aperture priority mode, it usually gives me the flexibility I need to make a creative exposure vs 'correct' exposure. In this example it would underexpose the photo 2 stops.
    However if you're just adjusting the f-stop down and setting for 'proper' exposure it won't change the actual exposure at all, it will just increase or decrease the shutter speed accordingly.
  7. manicmike
    Sep 29, 2009
    1,224
    307
    Oregon
    Thanks for the info everyone.
does exposure compensation affect f-stop?
exposure compensation f stop
exposure compensation vs f stop
exposure compensation vs f-stop
exposure compensation vs f-stop post
f stop compensation
f-stop compensation
is exposure compensation same as f stops
photography stop compensation
t stop compensation f stop
