Exposure Compensation
Discussion in 'Photography Beginners' Forum' started by hawee99, Sep 12, 2007.
  1. hawee99
    hawee99 TPF Noob!
    Jun 19, 2007
    229
    Colorado
    I'm hoping someone can explain this better than my book. I can't seem to fully understand it. Exposure Comp is that little +- button correct?
    What does it actually do? I understand this is supposed to make the picures brighter or darker, but on what level. When you go +1 or -1, does this actually effect the shutter or aperature. I don't think so, but I don't understand. When I have used this button in the past I have noticed it affect my light meter a lot, but I haven't noticed much different in the picture.
    Also, when shooting in "bracketing" , I understand it's supposed to take shots and different EV, example -2, 0, +2. When I shoot in bracket mode, I notice the shutter speed changing.
    Let me now if a can give anymore details to help understand my questions.
    Thanks.
    Nikon D80
  2. MarkCSmith
    MarkCSmith TPF Noob!
    Jul 19, 2007
    139
    4
    Toronto, Ontario, Canada
    It changes the aperature and shutter settings I believe.
  3. Sideburns
    Sideburns TPF Noob!
    Aug 14, 2007
    2,796
    Windsor, Ontario
    when bracketing is changing the shutter speed that over and underexposes the shot by 2 stops either way...it doesn't change aperture because then DOF would change.
  4. TCimages
    TCimages TPF Noob!
    Aug 18, 2007
    1,978
    4
    Northern Va
    It changes both depending what mode you are in.
  5. hawee99
    hawee99 TPF Noob!
    Jun 19, 2007
    229
    Colorado
    so if that's the case, why even have the button, i can change the shutter speed the normal way in manual mode
  6. TCimages
    TCimages TPF Noob!
    Aug 18, 2007
    1,978
    4
    Northern Va
    you can change the shutter speeds or aperture to change exposure, but EC allows you to easily change the exposure in incremental stops. I guess if you know what the shutter speed and/or aperture equivalent for each stop would be (for every scene) then you may be able to do it.
    Imagine shooting some flowers next to your house which is a bright white wall. The white wall will fool the cameras metering system into under exposing the flowers. So you will need to use the EC to stop the exposure up +1 or +1 1/2 . Hope that makes sense.
    With Practice, you will learn how many stop to add or subtract from a scene to get the correct exposure. The Camera will get it right probably 9 times out of 10.
    One thing I want to add, I think the EC actually alters the metering of the camera which impacts the shutter and/or aperture.
  7. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    Simple answer: you do not need Exposure Compensation when shooting manual! It only makes sense when you shoot in those semi-automatic modes like aperture priority or shutter priority or fully automatic. in these modes the amount of light hitting your sensor is defined by your meter reading only, and without Exposure Compensation you would have not chance to influence this amount of light.
    The light meter however, does not read your mind and hence does not know if you consider a scene exposed too bright or too dark and how you would like to get it exposed.
  8. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    I have used several cameras, and seen images from even more cameras. So I would say this is simply wrong ;)
    It is true for standard blue sky outdoor photography with the sun somewhere behind your back. It is also true for for well controlled studio light. But in all other cases cameras and their meters tend to fail totally.
  9. EOS_JD
    EOS_JD TPF Noob!
    Feb 15, 2007
    1,698
    Reading "Understanding Exposure" by Bryan Petersen helped me grasp what this was and how to use it.
    Now I regularly use EC. Keep an eye on the histogram and if you have under/over exposed an image try to understand why the camera's meter was fooled and then add/subtract an appropriate amount of EC until you get the correct exposure.
  10. The_Traveler
    The_Traveler Completely Counter-dependent Supporting Member
    Dec 11, 2006
    18,339
    7,569
    Mid-Atlantic US
    these sentences are the key answer.
    If the sun is behind the subject and the sun's glare is affecting the meter too much so that, without EC the subject would be underexposed, you would use EC to increase the exposure so that the subject is correctly exposed.
  11. hawee99
    hawee99 TPF Noob!
    Jun 19, 2007
    229
    Colorado
    yup that makes sense. thanks everybody for your replies. all very helpful, gotta go mess around with it now
  12. sabbath999
    sabbath999 No longer a newbie, moving up!
    Apr 11, 2007
    2,699
    68
    Missouri
    There is also another issue... remember, the "correct" exposure levels are determined by the engineers at the company that made your camera... and their views may or may not agree with your own.
    Also, like all things mechanical, there are trade offs... some cameras meter dark central subjects with brighter backgrounds completely differently... some cameras within the same line are even different.
    I find that there are differences between metering the exact same scene between a D200, a D80 and a D40.
    I often use a -0.7 on my D80 because I find that it overexposes a lot (IMHO) and work from there.
    Histograms and Chimping are your friends.
