Exposure Help
Discussion in 'Photography Beginners' Forum' started by charlie_merrifi, Mar 8, 2009.
  1. charlie_merrifi
    charlie_merrifi TPF Noob!
    Mar 5, 2009
    31
    Salem Oregon
    I am a severe noob here so bare with me. I bought a Canon xs and am having a heck of a time getting exposure right. Does anyone have any tips on how to help me get closer. I appreciate the help.
  2. dxqcanada
    dxqcanada Been spending a lot of time on here!
    Dec 4, 2008
    6,150
    927
    Woodbridge, Ontario, Canada
    First of all ... are you shooting in any of the Program / automatic modes ?
    What particular subject are you having problems exposing correctly ?
  3. Mgw189
    Mgw189 TPF Noob!
    Dec 31, 2008
    838
    Binghamton, NY
    There is a book called Understand Exposure that would be a huge help to you. Its by Bryan F. Peterson I believe. Some example pics would also help us figure out what your issue is.
  4. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    If you're using M, Av, or Tv it's as simple as lining up the bottom arrow with the top arrow (meter at the bottom of the viewfinder). In mixed lighting conditions this won't always be perfect, but it will be closer than just guessing.
    To make that little needle on the bottom move you have to change the shutter speed (faster will move it towards the negative side) or the aperture (higher f/# will also move it into the negative).
    Also - what metering mode do you have it in?
  5. charlie_merrifi
    Mar 5, 2009
    31
    Salem Oregon
    dosent really seem to matter what im shooting. Im usually in manual mode. sometime apreture priority if im doing waterfalls. I didnt even think about looking at the meeter in the bottom. Duh that would probably help. And I always have it in evaluative metering mode. WHen should I use the other metering modes.
  6. jands
    jands TPF Noob!
    Dec 21, 2008
    161
    13
    Tacoma, WA
    This helped me tons! Moving Toward Manual Settings
    At the very beginning there are links to the first 3 parts, I recommend reading them first.
    This article is just a summary but has a different way of looking at it. Exposure Triangle
    Hope that helps.
  7. AlexColeman
    AlexColeman TPF Noob!
    Dec 13, 2008
    1,732
    Another thing that might help is re-reading your posts so that they are legible.
  8. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    Evaluative will try to make the entire scene a "good" exposure. Center weighted does the same, but the center is more important in the camera's decision making process. Spot or Partial only looks at the center of the image (some cameras attach it to the active focus point, that's mostly only on high end bodies) and ignores everything else.
    Spot metering will meter for whatever you point it at. If that happens to be brighter than everything else around it, it will be properly exposed but all that other stuff will be underexposed (and the other way around). Sometimes that's good, sometimes it's not.
  9. mosu84
    mosu84 TPF Noob!
    Dec 15, 2008
    185
    Boston
    People who live in glass houses...
