Exposure meter - needed with a DSLR ?
Discussion in 'Photography Beginners' Forum' started by ottor, Jun 10, 2009.
  1. ottor
    ottor No longer a newbie, moving up!
    Feb 7, 2009
    935
    173
    S. Idaho
    What exactly is it, how do you use it, and is it needed with the new digital cameras and their exposure metering within the camera itself?
    tks,..
    r
  2. harrison
    harrison TPF Noob!
    Jun 9, 2009
    26
    Clemson, SC
    I honestly had never used mine up until about a month ago. After reading a photography book based in the film era, I got the motivation to keep my camera in Manual for a few days and try my hand at doing things the old school way. Its a useful tool, slightly outdated and useless if you keep your camera in an auto mode, but it makes manual mode much quicker. It helped me learn a lot about f-stops and what light combinations produce what effects.
  3. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    I do not have any stand alone light meter. I just use the light meter that build-in with my DSLR. And I believe all of the DSLR has a light meter build-in already. But it is a reflected type. In other words, it uses the reflected light from the object / background to determine the correct exposure.
    And different cameras has different Metering modes. Entry level DSLR usually has less Metering modes. Typical metering modes are Partial, Spot metering or Center-weighted average etc.
    So for me, I really do not need any stand alone light meter.
  4. bigtwinky
    bigtwinky No longer a newbie, moving up!
    Oct 6, 2008
    4,820
    285
    Montreal
    If you are shooting in Automatic, Program, Aperture Priority or Shutter Priority, you don't really need it. Each of these settings will have some camera logic built into it that will ensure an exposure in the middle of your meter (proper exposure).
    If you are shooting in manual mode, then you do need the meter to see if your settings will give a wanted exposure.
  5. mrodgers
    mrodgers No longer a newbie, moving up!
    Dec 13, 2007
    1,662
    7
    My lowly cheapo superzoom has a light meter display when in manual mode. I assume most if not all dSLRs do as well.
    The exposure compensation display changes to the meter display when going manual. If I dial in -0.7 on exposure compensation and it gives me 1/250 seconds on Aperture priority using f/5.6, then setting 1/250 and f/5.6 in manual will display -0.7 on the display when in manual.
  6. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    Practically all modern cameras have a built-in "reflected" light meter...that's how the auto modes set the exposure.
    There are still advantages to a hand held meter, but they certainly aren't a requirement.
    There is also this...Understanding Histograms
  7. KmH
    Apr 9, 2009
    40,758
    5,588
    Iowa
    The in camera light meter only measures reflected light.
    There are times, particularly when shooting portraiture, when you may want to measure incident light and flash output at the subject.
    In those cases you would need a hand held meter.
    Here's one that could handle the job.
  8. Steph
    Steph No longer a newbie, moving up!
    Oct 18, 2006
    1,314
    Steventon, Oxfordshire, UK
    Well, even in manual mode you can use the light meter built in the camera.
  9. bigtwinky
    Oct 6, 2008
    4,820
    285
    Montreal
    hot damn, I misread the question. I thought the question was about the meter that is IN the camera, not the external meter that you can use outside the camera
    sorry
  10. Overread
    May 1, 2008
    24,079
    4,175
    UK - England
    As Big Mike said mostly external meters used today are used for juding exposures with flash. However with histograms, free shooting and in camera meters if you have time to take more than a few shots then I don't think you really need an external meter at all.
    Might be a handy thing for studio and portrait work, but I would not put it to the top of the to get list by any means
