exposure question
Discussion in 'Film Discussion and Q & A' started by spiffybeth, Apr 14, 2008.
  1. spiffybeth
    spiffybeth TPF Noob!
    Nov 6, 2007
    3,671
    4
    NJ
    tonight ill be shooting in a very low light environment (a bar). last time i shot it, i was shooting digital so i could adjust my settings as i saw fit, but this time id like to shoot film.
    the settings i had it on was iso 1600, f/3.5-5.6 18-55mm (kit lens) and i set the shutter for 1/30.
    this time, im going to be using film. iso 400 and a 50mm f/1.7. what should my shutter be to keep that same exposure?
    what about if i shot at f/2.8?
  2. Battou
    Battou No longer a newbie, moving up!
    May 10, 2007
    7,997
    26
    Slapamonkey, New York
    that ain't gonna cut it I don't think.
    My self I would be using 800 and 1.4 (in your case 1.7) and keeping the shutter as fast as possible.
    But not knowing the exact light situation I can't be sure if that is too much or too little....this is one of those things one has to be there and read them selves to give the best advice.
  3. spiffybeth
    Nov 6, 2007
    3,671
    4
    NJ
    ok, lets say i had iso800 and the lighting was the same as the first scenario. what then?
  4. Battou
    May 10, 2007
    7,997
    26
    You'll have to jog my memory
  5. spiffybeth
    Nov 6, 2007
    3,671
    4
    NJ
    see the first post.
    there must be an equation i can solve to find the answer, right????????
  6. Battou
    May 10, 2007
    7,997
    26
    I am horrible with equations, I was hoping for a link to the afore mentioned outing so I could see it.
  7. Steph
    Steph No longer a newbie, moving up!
    Oct 18, 2006
    1,314
    Steventon, Oxfordshire, UK
    What aperture did you use when you shot the scene with your digital camera?
  8. KevinDks
    KevinDks TPF Noob!
    Jul 9, 2007
    158
    Burley, Hampshire
    Well, f/2.8 is two thirds of a stop faster than f/3.5, so if 1/30th at f/3.5 was OK at ISO 1600 then f/2.8 at 1/30th will be a third of a stop under that exposure at ISO 800. With negative film that shouldn't be a problem, but I think I'd make sure I had a mixture of shots that included some with a bit more exposure as well.
  9. spiffybeth
    Nov 6, 2007
    3,671
    4
    NJ
    f/3.5 and f/5.6
  10. spiffybeth
    Nov 6, 2007
    3,671
    4
    NJ
    and if i went with f/1.7, at 1/30, that should be ok?
  11. KevinDks
    KevinDks TPF Noob!
    Jul 9, 2007
    158
    Burley, Hampshire
    f/1.7 is another stop and a half faster than f/2.8 and so, let's see if I can keep track here, err - about two thirds of a stop to a stop more exposure than you had with your digital at f/3.5 and 1/30th I think. Bracket between those kinds of settings and the latitude in negative film will take care of the rest.
    This wiki page has useful tables which set out the f/ number sequence in half and third stops
    This web page has a chart that gives you a rule of thumb exposure guide for all kinds of situations, and equivalent exposures.
    Kevin
  12. spiffybeth
    Nov 6, 2007
    3,671
    4
    NJ
    thank you very much, kevin!!!!!
