exposure?
Discussion in 'Photography Beginners' Forum' started by Simonch, Nov 11, 2007.
  1. Simonch
    Simonch TPF Noob!
    Feb 17, 2006
    77
    I Live in Stonehaven, which is located in the Nort
    Hey folks,
    Was away out to try and shoot an HDR shot for the first time.... cant seem to figure out the settings on my 350d tho, if i shoot in aperture or shutter priority, it just adjusts the other so that the exposure is always correct, and if shooting in fully manual, i cant seem to adjust the exposure at all!! grr... so confused! if you could help, this would be great!
    cheers
  2. Flash Harry
    Flash Harry No longer a newbie, moving up!
    Jun 26, 2006
    1,961
    13
    Durham, UK
    1 expose for the highlights = the sky/brightest part of an image
    2 expose for the shadows = darkest part of an image you need info from
    3 one correct exposure of the overall scene.
    so one under exposed, one overexposed and one correct. Then do what you do in pp. H
  3. Coldow91
    Coldow91 TPF Noob!
    Sep 14, 2007
    1,370
    USA
    I would suggest that you read about manual mode in your manual.
  4. Simonch
    Simonch TPF Noob!
    Feb 17, 2006
    77
    yeah coldow, couldnt find it!! managed to rake it out and found out a bit more of what i was needing! thanks guys
  5. Sideburns
    Sideburns TPF Noob!
    Aug 14, 2007
    2,796
    Windsor, Ontario
    If you're using a Canon...you use the dial to adjust the shutter speed in manual...and if you push the Av button on the right side of the screen, and move the dial, then you can change the aperture.
    I'm not sure what you mean by "exposure" in that post...
    Go to your menu and turn on AEB (auto exposure bracketing) to whatever spread you want... like +1 and -1 stop or +2 and -2 stops.. and then just click the shutter 3 times and bingo...you got three shots.
  6. Coldow91
    Coldow91 TPF Noob!
    Sep 14, 2007
    1,370
    USA
    Glad you found what you needed! I would have told you the way to do it if I knew but I have a nikon.
  7. RyanLilly
    RyanLilly No longer a newbie, moving up!
    Aug 27, 2007
    1,478
    8
    St. Louis, Missouri, USofA
    When shooting for HDR, you should also keep the same f-stop for each exposure, that way DOF is not changed. Use manual mode and adjust shutter speed.
