Extension tubes
Discussion in 'Photography Equipment & Products' started by KylePeterson, Mar 18, 2009.
  1. KylePeterson
    KylePeterson TPF Noob!
    Dec 31, 2008
    139
    Albert Lea, MN
    Was reading in a book about these extension tubes that help focus close. Anyone use them and recommend them? How much do these take the place of a macro lens?
    What about sizes? 12mm? bigger?
    thanks
    Kyle
  2. Big Mike
    Dec 16, 2003
    33,864
    1,822
    Edmonton
    They can be a great option for macro photography. Firstly because they don't introduce any glass into the light path...so you don't loose quality. Also, they are cheaper than a true macro lens.
    I haven't compared tubes directly to a good macro lens, but I think that most would prefer an actual macro lens (except for the price).
  3. justnuts
    justnuts TPF Noob!
    Mar 18, 2009
    6
    I have a set I use with my macro lens and they are great. I have tried them on my 50mm and for things that don't move they are ok but if you are trying to shoot bugs you have a very short working distance. Some people swear by them on a 50mm. I have the kenko set of three that you can use a single or in combinations. Tubes are a cheap way of seeing if macro is for you.
  4. Moonlighter
    Moonlighter TPF Noob!
    Mar 11, 2009
    31
    interesting device..
  5. Mike_E
    Jan 26, 2007
    5,327
    266
    I use them occasionally. I prefer to use them with an old 70-210mm zoom because you can quickly center the DoF on the subject (after you set the focus) by zooming back and forth so you can use it hand held.
    I don't know of anything that will work with something that's moving fast but I can generally get a shot in good light. The Continuous High setting helps too. ;)
  6. KylePeterson
    Dec 31, 2008
    139
    Albert Lea, MN
    If I was only going to get one, which size would you recommend? 12, 24, 36?
  7. Mike_E
    Jan 26, 2007
    5,327
    266
  8. benhasajeep
    benhasajeep No longer a newbie, moving up!
    May 4, 2006
    3,288
    312
    Eddington, ME
    I have a set of Kenko AF extension tubes for my Nikons. I use them with and without a macro lens. There is no glass involved so its purely a mechanical thing, no worries about cheap glass components or things like that.
    Each size can be used seperately or they can be stacked in any combination including all 3 at once. So, having a set has some advantages.
    Need a good firm tripod though. As the closer you focus the steadier you need to keep the camera to avoid shake.
  9. xiangji
    xiangji TPF Noob!
    Jul 26, 2009
    126
    Anyone have example shots of extension tubes with a canon 50mm 1.8 II?...as I'm thinking about getting extension tubes.
  10. Dwig
    Dwig TPF Noob!
    Mar 11, 2009
    1,261
    Key West FL
    It depends on what lens you will use on the tubes. The effect of an extension tube of a particular length is proportional to the focal length of the lens. A 12mm tube will have a major effect on the magnification achieved with a wide angle of 18mm or so but little effect on a long 200mm telephoto. In the first case the length of the tube is 66% of the focal length. In the latter, it is only 6%.
