Extension Tubes
Discussion in 'Photography Beginners' Forum' started by florenceinitaly, Jan 21, 2010.
  1. florenceinitaly
    florenceinitaly TPF Noob!
    Jan 7, 2010
    89
    I've seen extension tubes mentioned as a good macro lens alternative in several photography books that I'm reading - after googling them they look like they would be a good accessory to have.
    My question is though, since there are no electrical connections in the extension tubes, how do you control focus and aperture? For focusing I guess manual focus would be fine, but I can't control aperture manually on my camera - how is this going to work?
  2. Overread
    May 1, 2008
    24,072
    4,172
    UK - England
    The very cheap tubes do not have the electrical contacts and so yes you are correct - that means you can't control the aperture. With canon camera lenses you can trick the blades to be shut all the time at a set aperture, but that is not only fiddly, but also means that you have to focus a shot at small apertures which means a very dark viewfinder image - even for manual focusing (since AF is not possible with such a setup and manual focusing is also preferable when shooting macro)
    The trick is to get some better tubes - the Kenko AF range of tubes do have the electrical contacts and thus will preserve your communication with the lens.
    Another alternative is to use a highquality diopter on the lens - such as a Raynox DCR 250 or Canon 500D (product name for canons diopter lens as well as a camera model) which will work in a similar way as the tubes, but with a glass element on the front of the lens. Image quality wise its not too dissimilar from using tubes to get to such magnifications (dispite common thinking tubes do cause some image degradation, but in most cases is far to minor to concern ones self about and other factors such as shutter speed, subject movement and handshake will have a far greater impact on the photos quality)
  3. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    Some extension tube has electrical contacts.
    i.e. Promaster
  4. c.cloudwalker
    c.cloudwalker TPF Noob!
    Jun 15, 2009
    5,394
    405
    An American in Europe
    First of all, yes, you can control your aperture manually. Unless you have a P&S. Read your manual.
    Second, when it comes to macro work, I don't think manual focus and exposure is much of an hindrance but I don't do much macro so somebody else may very well correct me on that one.
    I use an extension tube for the very little macro work I do and I find it just fine but it is not serious photo work so it really doesn't matter.
  5. florenceinitaly
    Jan 7, 2010
    89
    Doesn't it depend on what lens you have? Some have an aperture ring for manual control but some doesn't. I don't think mind does, so how can I still manually control aperture? =S
  6. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    You are correct, not all SLR lenses are capable of having the aperture adjusted manually. All Canon EF lenses for example, need to be connected to the camera for aperture control.
  7. florenceinitaly
    Jan 7, 2010
    89
    So then if I don't have aperture ring, and i connect one of these extension tubes without electrical connections, what will my aperture be? wide open or small?
  8. Dao
    Mar 24, 2008
    6,252
    418
    St. Louis
    If your camera is the Canon EOS, it will be wide open. And I believe Nikon is the other way around (I could be wrong)
  9. florenceinitaly
    Jan 7, 2010
    89
    how about a sony a500 lol
  10. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    Lenses default to wide open. When you look through the viewfinder of an SLR camera, you are looking into a mirror and out through the lens. If the lens was stopping down, the viewfinder would get darker and darker.
  11. Dao
    Mar 24, 2008
    6,252
    418
    St. Louis
    Maybe unmount the lens from the camera and look at the glasses. If you do not see any shutter blades, then the lens is wide open.
  12. c.cloudwalker
    Jun 15, 2009
    5,394
    405
    My bad. Shows you how much I still have to learn about digital...:grumpy:
