Extension Tubes
florenceinitaly
I've seen extension tubes mentioned as a good macro lens alternative in several photography books that I'm reading - after googling them they look like they would be a good accessory to have.
My question is though, since there are no electrical connections in the extension tubes, how do you control focus and aperture? For focusing I guess manual focus would be fine, but I can't control aperture manually on my camera - how is this going to work?
The very cheap tubes do not have the electrical contacts and so yes you are correct - that means you can't control the aperture. With canon camera lenses you can trick the blades to be shut all the time at a set aperture, but that is not only fiddly, but also means that you have to focus a shot at small apertures which means a very dark viewfinder image - even for manual focusing (since AF is not possible with such a setup and manual focusing is also preferable when shooting macro)
The trick is to get some better tubes - the Kenko AF range of tubes do have the electrical contacts and thus will preserve your communication with the lens.
Another alternative is to use a highquality diopter on the lens - such as a Raynox DCR 250 or Canon 500D (product name for canons diopter lens as well as a camera model) which will work in a similar way as the tubes, but with a glass element on the front of the lens. Image quality wise its not too dissimilar from using tubes to get to such magnifications (dispite common thinking tubes do cause some image degradation, but in most cases is far to minor to concern ones self about and other factors such as shutter speed, subject movement and handshake will have a far greater impact on the photos quality)
First of all, yes, you can control your aperture manually. Unless you have a P&S. Read your manual.
Second, when it comes to macro work, I don't think manual focus and exposure is much of an hindrance but I don't do much macro so somebody else may very well correct me on that one.
I use an extension tube for the very little macro work I do and I find it just fine but it is not serious photo work so it really doesn't matter.
Doesn't it depend on what lens you have? Some have an aperture ring for manual control but some doesn't. I don't think mind does, so how can I still manually control aperture? =S
You are correct, not all SLR lenses are capable of having the aperture adjusted manually. All Canon EF lenses for example, need to be connected to the camera for aperture control.
So then if I don't have aperture ring, and i connect one of these extension tubes without electrical connections, what will my aperture be? wide open or small?
If your camera is the Canon EOS, it will be wide open. And I believe Nikon is the other way around (I could be wrong)
Lenses default to wide open. When you look through the viewfinder of an SLR camera, you are looking into a mirror and out through the lens. If the lens was stopping down, the viewfinder would get darker and darker.
Maybe unmount the lens from the camera and look at the glasses. If you do not see any shutter blades, then the lens is wide open.
My bad. Shows you how much I still have to learn about digital...:grumpy:
I have an extension tube mentioned in my signature, that model lets my 100mm f/2.0 and 70-200 f/2.8L focus just as fast as before. No lose in any on camera controls, go Canon, I love the one I got...
ALIAS
so given that, if I mount on the extension tube, then I'm stuck at my widest open aperture, and wouldn't be able to make it any smaller correct?
Sorry just not grasping this very well
If you use an extension tube that does not permit communication between camera and lens, then yes, the lens will probably remain wide open (unless it's a lens with manual aperture controls).
