external flash issue
Discussion in 'Beyond the Basics' started by namiam, May 2, 2010.
  1. namiam
    namiam TPF Noob!
    May 2, 2010
    I have a Sony R1 with a HVL-F32x external flash. Suddenly, the external doesn't work anymore. My settings in the menu are as when it worked before. I have cleaned the shoe fine. The flash still works when I press the "test" button and "modeling" button on the flash though.
    Any ideas?
    T.I.A.
  2. Big Mike
    Dec 16, 2003
    33,830
    1,812
    Edmonton
    Double check to make sure that the flash is fully seated on the hotshoe.
  3. namiam
    namiam TPF Noob!
    May 2, 2010
    sorry about posting in the wrong section.
    I have triple, even quadruple checked that the flash is fully seated in the hotshoe. The flash says "connected" when the camera is on. When I move the flash around the hotshoe just a tad, SOMETIMES it loses connection. But anyways, when it says "connected" the flash does not function correctly.
  4. gryphonslair99
    gryphonslair99 Been spending a lot of time on here!
    Sep 9, 2006
    11,483
    2,109
    Wichita, Kansas, USA
    Have you by chance disabled external flash firing. Most bodies have something similar that will tun off flash firing, and will usually kill the hotshoe as well.
  5. namiam
    namiam TPF Noob!
    May 2, 2010
    I have it setup just like it has on the owner's manual for the flash and the camera, and no flash still. I have also tightened the flash in the hotshoe pretty tight, but still no flash!
  6. KmH
    Apr 9, 2009
    38,459
    5,080
    Iowa
    There are only 2 possibilities left:
    1. The body is not geneerating a trigger signal
    2. or the speedlight doesn't detect the trigger signal from the body.
    Time to get out the multimeter to check there is in fact a trigger signal from the body, or send both in to Sony.
  7. Flash Harry
    Flash Harry TPF Noob!
    Jun 26, 2006
    1,918
    Durham, UK
    have you chosen a mode such as "program" which has disabled flash? H
