External Flash
Discussion in 'Photography Beginners' Forum' started by ABPASnapshot, Aug 26, 2008.
  1. ABPASnapshot
    ABPASnapshot TPF Noob!
    Aug 26, 2008
    19
    ...I have a Canon EOS Rebel T2 and do not have a shoe mounted flash; in fact, I have never used one...what are the advantages and what would I have to pay for a decent external flash?...
  2. tirediron
    Jul 8, 2005
    41,108
    12,493
    Victoria, BC
    The advantages are: More output (brighter flash), quicker recycle time, less drain on the camera's battery, the ability to bounce the light (and in some cases use off-camera). Depending on whether you buy new or used, Canon-made or third party, you can pay anywhere from $25 - $500+. Check out your local camera store for used gear. Sunpak made a decent line of flashes for Canon, many of which should be available cheaply. Bear in mind that some of the older and/or less sophistacted third-party models may not offer TTL flash metering or other automatic functions.
  3. William Petruzzo
    William Petruzzo TPF Noob!
    Aug 22, 2008
    635
    Washington DC
    Adding a shoe mounted flash is one of the simplest things you can do to quickly add lot of horsepower to your photographs; namely because of the ability to bounce light. Once you've gotten a handle on using your camera and are ready for a new challenge, I definitely recommend you add an off camera flash.
  4. KabeXTi
    KabeXTi TPF Noob!
    May 30, 2008
    163
    Southern California
    Sorry to thread-jack here, but I am just starting to learn about external flash and I have one simple question:
    To fire an SB-600 off camera what do I need?
  5. KabeXTi
    KabeXTi TPF Noob!
    May 30, 2008
    163
    Southern California
    P.S. Using a D40 body as well.
