Zimmermakr
- Joined
- Feb 24, 2015
- Messages
- 2
- Reaction score
- 0
I recently purchased a Nikon FE2 off of eBay. Everything seemed to work properly at first, but when looking back at my first roll of film, I noticed that there was a slight dark band at the top of each image. I attached some pictures from a contact sheet to show the problem - that light stripe at the top of each frame. It is more noticeable in some images then others but is consistently there.
Does anybody know what this problem could be? Could it be something as simple as bad light seals, or is it more likely a mechanical issue? I had a photography professor watch as the shutter fired and we were unable to tell if that was the problem.
If light seals are a likely culprit, what is an average cost for having them replaced? Could I potentially damage the camera if I attempt to fix them myself by getting a kit and following the instructions?
I've also attached a couple of pictures of the camera's interior.
Thank you so much.
Thank you so much.
