f-stop question...
Discussion in 'Beyond the Basics' started by railman44, Oct 25, 2004.
  1. railman44
    railman44 TPF Noob!
    Aug 23, 2004
    580
    Lincoln, NE
    Can someone please clarify an f-stop question I have? When I read a certain filter needs (let’s say) down or up 1 f-stop what does that mean? Down or up from what? Down or up from where your meter tells you when you have a correct setting without the filter? I’m assuming this is what it means?? Thanks for your help!
  2. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    It means that the filter lets 1 stop less light through. You need to open your aperture by 1 stop, or lower your shutter speed by 1 stop to compensate for the loss of light.
    If your camera has ttl metering, it will meter correctly with the filter on. If you were using a handheld meter, you would have to make the change yourself.
  3. ksmattfish
    Aug 25, 2003
    7,019
    34
    Lawrence, KS
    Read up on stops and f/stops in the stickie post at the top of this forum "Vocabulary for newbies".
