On what?Ok...stupid question time again...where is the guide number?
From HEREGuide number (power output).
The unit has a zooming flash head which moves internally to adjust for the lens focal length. Control over the zoom position is both manual and automatic. The zoom range is from 24-105 mm, with zoom detents (stops) at 24, 28, 35, 50, 70, 80 and 105mm.
The flash zoom function is capable of taking the camera’s image sensor size into account if the camera is also capable of transmitting that data to the flash unit. In such a case the flash can adjust its zoom to match a reduced (less than 35mm film frame) sensor size, and so wastes a minimum of light around the edges.
The unit’s guide number (provided in metres, not feet, for ISO 100) varies depending on the zoom head settings.
At 14mm (with the flip-down diffuser in place) the guide number is 11.
At 24mm the guide number is 25.
At 28mm the guide number is 27.
At 35mm the guide number is 31.
At 50mm the guide number is 34.
At 70mm the guide number is 37.
At 80mm the guide number is 40.
At 105mm the guide number is 43.
On what?
It's usually on a flash somewhere and certainly in the spec sheet/manual.
The 430EX has a guild number of 43 meters (that's convenient)...which is 141 feet. And that's at ISO 100.
Also, the Guide number will change, based on the zoom setting of the flash head.
From HERE
Also, keep in mind that the Guide Number is the flash at full power.
So if you want to shoot at half power on the 430, you shoot at half of 141', 70.5'. If you want to shoot at 1/4 power, you half the guide number again - 35.25'.
Don't sweat it. This stuff can be very technical...it's not imperative that you have a full understanding of it. As suggested, just practice, practice, practice. You will eventually get a better 'feel' for what works and what doesn't. And that's what really counts. The numbers may or may not sink in over time...but it will get easier to understand...I promise.I am so confused. I'm sorry...I'm sure it's frustrating trying to explain this to me...It's just not clicking.
With digital, it's fairly easy because you can guess and test. Just fire a test shot, maybe starting at 1/2 or 1/4 power (on the flash) and adjust it from there.Say I am doing a portrait, indoors, with my 50mm lens. I have my one flash on a light stand, and its about 10 feet from the subject. (no umbrella or gels or anything) I am wanting to use an aperture of 5.6. WHAT DO I DO FROM HERE? Is this even a example that will work?
Er, are you sure about that? It's a square thing, you know.
If full power is a GN of 141 feet, half power is a GN of 100 feet. 141 divided by root 2 (1.414) is 100.*
*Edit: The same relationship holds for film speed. If the quoted GN is 60 metres at ISO 100, it will be 84 metres at ISO 200, 120 metres at ISO 400, and 42 metres at ISO 50.
Best,
Helen
