F stops??? I'm a nub cake.
Discussion in 'Photography Beginners' Forum' started by mikerocks4250, Mar 31, 2009.
  1. mikerocks4250
    mikerocks4250 TPF Noob!
    Jan 25, 2009
    14
    Well I'm in my 3rd semester of photography, and I have no idea if I'm using my aputure right and WAY to embarest to ask. I really missed alot of the first year, but I went off what my Friend told me. Then i was in a class and some1 told me i was wrong but they are very sarcastic so idk. For land scape I use a higher f-stop so that everything will be in focus. I use lower for still life.
    I really like photo and want to do nohing but get better. Please if anyone could help me with the apputure and dof. My pictures I have had in class so far have not seemed to be bad.
    My goal for my next shoot I want to go to a local skatepark and get some sick pics of my friends. My idea for this is to have them(subject) crisply in focus and back round out of focus. I usaly do this just with my focus, but since the skate park is big I might need to be farther way. Any ideas? Other then panning.
  2. adolan20
    adolan20 TPF Noob!
    Dec 12, 2007
    261
    New Hampshire
    Well in order to get the skaters with the background blurred out you would need a lower f/stop which should let you use faster shutter speeds to freeze your friends.
  3. tirediron
    Jul 8, 2005
    41,108
    12,493
    Victoria, BC
    Apeture: Small number (f 1.4, f 2) = large aperture, shallow DoF. Large number (f11, f16) small aperture, large DoF. Generally speaking, the wider the field of view, the greater the DoF at a given aperture; in other words, wide-angle lenses have much greater DoF at a given aperture then a telephoto.
    Have a look at this on-line DoF calculator for a more detailed explanation.
  4. Sherman Banks
    Sherman Banks TPF Noob!
    Feb 24, 2009
    871
    Rain City
    No need to be embarrassed, we all started somewhere.
    Here is how it works:
    Smaller f-stop= Larger Aperture= Shallow depth of field
    Larger f-stop= Smaller Aperture= Deep depth of field
    As for taking the photos of your friends skating, you'll want to shoot with your lowest f-stop available, but the tricky part will be the focus since he won't be in a fixed position. You may want to manual focus on this as the autofocus may not be able to lock in time. If you don't get the results you want on the camera, you can do some work in photoshop to create the same effect as a shallow DOF. Hope this helps and good luck shooting with your friend. Post some pics of the results.
  5. Pure
    Pure TPF Noob!
    Oct 22, 2008
    420
    I recommend you read UNDERSTANDING EXPOSURE by BRYAN PETERSON.
    F-stops control 2 things, the amount of light hitting the sensor, and DOF or depth of field. A low F number such as F1.4 will give you a shallow DOF. A high F number such as F22 or whatnot will give you a much wider DOF. It also controls the amount of light hitting the sensor. Because of this, lenses that are F2.8 or larger are usually reffered to "fast glass" becuase a lot more light can hit the sensor, a large opening.
    In terms of F stops, 2.8, 4, 5.6, 8, 11, 16, 22, 36 and others are caled "full stops. As you progress from lets say 2.8 to 4, you allow HALF the amount of light to enter. A full stop basically divides the amount of light by 2 or multiplies it by 2.
    That's just the beginning, hope this helps.
  6. JE Kay
    JE Kay TPF Noob!
    Mar 12, 2009
    218
    SW Ontario
    Not to sound like an ass, but how can you be in the third semester and not know this?
    Not a knock on you, but that's kind of the first thing we went over when I was in school.
  7. mikerocks4250
    Jan 25, 2009
    14
    Dude I ask my self that everyday Lol. But I guess I was some what right. But I understand all the other basic stuff to a good photo light, placement, and contrast.
    Thanks to the rest really really really heplfull.
    To Sherman tirediron
    I'm shooting flim, but after I make a few 5x7's I could scan them and post, or get my digital cammera quicker and post a few.
  8. nikonguy
    nikonguy TPF Noob!
    Mar 11, 2009
    90
    also if your wanting to get decent skate shots, your really going to need a fisheye.. otherwise you will have to be to far away from your subject in order to get everything in the shot...
  9. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
  10. Graham18ce
    Graham18ce TPF Noob!
    Jan 29, 2009
    53
    Milton, ON Canada
    The simple reason i have noticed in the past with people that don't understand the basics of sutter to aperture is bad teachers. This is something that you never fully get to master as there are the basics measures and rules of principle and then you start to go outside the basics and adjusting to suit the wanted effects.
    I have met many a teacher that was great at getting the basics to you and questioning the reason you did each setting thoughout the program, it forces you to think in the settings mode of what will the result be if i do this or that.
    I have also met teachers which are great at comp, film processing, darkroom technique, truly wizards when it came to lighting, however, you never really learn the basics of how to get a desired effect when it came to dof, stop action, motion blur, etc...
  11. gsgary
    gsgary Been spending a lot of time on here!
    Oct 31, 2008
    16,144
    2,945
    Chesterfield UK
    It sounds like your teacher should be sacked, this is the first thing you should have been taught
  12. CraniumDesigns
    CraniumDesigns TPF Noob!
    Dec 1, 2008
    477
    San Francisco Bay, CA
    I 2nd this. It's $15 on amazon and helped me learn so much in a very short time.
