Family Photoshoot Happening NOW, looking for some help
Discussion in 'Photography Beginners' Forum' started by chrisburke, Nov 25, 2008.
  1. chrisburke
    chrisburke TPF Noob!
    May 25, 2007
    2,107
    Madoc, Ontario Canada
    so most of the studio work i've done is just individuals.. not groups.. i normally do those outside... i'm trying to do MY family shot and I cant seem to get this lighting stuff down.... the following is a picture of my set up that is there right now just waiting for us to sit into position...
    the problem i'm having is, even though i have a flash on the right side, its still very dark over there in the pictures...
    [​IMG]
    I even tried putting a reflector over there to bounce the light more, and it didnt do anything... heres an example... ignore the lamp on the left side, i realized pretty quick to shut that off..
    [​IMG]
    it almost looks as though that flash isnt even firing, but it is.
    any help is appreciated.
  2. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    How are you triggering that other flash? If it looks like it's firing but not showing up in the photo...it's probably some sort of trigging mishap. For example, are you using E-TTL on your main light and using an optical trigger on the slave?
  3. chrisburke
    May 25, 2007
    2,107
    the flash on the white umbrella is via wired hot shoe and the other is a SB 50 which has a built in optical slave
  4. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    I though so...that's your problem.
    When a flash is connected to the hot-shoe and in E-TTL mode...it fires a pre-flash for metering, then fires again for the exposure. The optical slave on the other flash will trigger when it detects the pre-flash...and it won't be able to fire again for the exposure because it happens so fast.
    The solution is to put your main flash into manual mode, which should prevent it from firing a pre-flash. You will then have to figure out and set your flash power manually.
  5. stsinner
    stsinner TPF Noob!
    Oct 27, 2008
    1,860
    8
    Massachusetts
    Are you and your wife wearing the same shoes? I think that may be the problem. LOL...
    After playing with my setup, I can tell you that you can see a flash fire and not see it help the picture at all!! Slow your shutter down-that worked for me. Of course you'll have to adjust your aperture a stop or three, also.
    I actually took pictures of the remotes and could see that they were not on, but my eyes saw them fire.. Shutter was too fast to realize their light.
  6. chrisburke
    May 25, 2007
    2,107
    Thanks mike.. we can always count on you
    lol they are similar
    well this sucks.. the light that is on the wired slave doesnt seem to have a manual mode.. all its got is an on button, and some exposure buttons... can i set it to manual mode through the camera?
  7. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    What flash model is it? I would think that most TTL capable units would have a manual mode.
    Do you have another way to trigger the main flash?
    It's also possible that your shutter speed is too fast for the slave flash to trigger in time. What shutter speed are you using?
  8. chrisburke
    May 25, 2007
    2,107
    I'm using the sunpak pf30....just doing some reading to see if there is a way to put it in manual mode
    i've made a few adjustments and heres what im getting now...
    [​IMG]
    exif is as follows:
    1/60th sec F5.0 ISO 200
    still getting some shadow.. the flash is so quick i cant really tell if they are firing together or not...
  9. stsinner
    stsinner TPF Noob!
    Oct 27, 2008
    1,860
    8
    Massachusetts
    A pro friend of mine told me to start at f/8, ISO 100 and shutter at 1/100. That got me going as a baseline, although the aperture didn't work.
    Is there a chat room on this site where you could get more real-time help from Mike?
  10. chrisburke
    May 25, 2007
    2,107
    poor mike would be so busy!!! it would be a full time job managing that
  11. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    Is the Sunpak a TTL capable (dedicated) flash? I thought you would be using a Nikon flash.
    I'm not sure exactly what your problem is, sorry.
  12. chrisburke
    May 25, 2007
    2,107
    Sunpak supports D-TTL, i-TTL, and TTL flash compatability
    i have one nikon and one sunpak
