FD-EOS adapter
Discussion in 'Photography Equipment & Products' started by pwnstar max, Feb 28, 2007.
  1. pwnstar max
    pwnstar max TPF Noob!
    Feb 1, 2007
    45
  2. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    The problem with these...is that it requires it's own lens to make up for the added space that it takes up behind the lens. Typically, this lens is less than great...and it adversely affects the image quality. If you do have some good lenses, then it may be worth a try...but don't expect fantastic results.
  3. Don Simon
    Don Simon TPF Noob!
    Jul 4, 2005
    2,484
    Yes unfortunately you need an adapter with optical elements to use FD lenses on an EOS and retain infinity focus. It might be possible to use an adapter without glass for macro work. Otherwise I can't see the adapters being much good, unless they're the official Canon ones brought out when they made the change to EOS; I expect they would have good optics but not cheap ebay ones.
  4. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    346
    North New Jersey, United States of America
    The EF/FD adapters put out by Canon are not only expensive but rare too. IIRC they were never sold to the open public.
  5. SaSi
    SaSi TPF Noob!
    Sep 23, 2006
    63
    I have one of those. You can get them much cheaper (~$11 - 15)
    They are great for Macro shooting, if you remove the glass element. Otherwise, using it for normal shooting, with the lens element, will deteriorate the quality of your lens beyond recognition.
    I tried an FD 50/1.2 on my EOS 350D using this adapter and the chromatic abberation was extravagant. With a darker FD300/5.6 stopped down at f/11 the results were much better when I did some landscapes and shots of the moon.
