FD Mount Lenses with a Canon 50D...
Discussion in 'Canon Lenses' started by BuS_RiDeR, Jul 13, 2012.
  1. BuS_RiDeR
    BuS_RiDeR No longer a newbie, moving up!
    Oct 29, 2009
    2,356
    83
    Riverview, New Brunswick, Canada.
    Am I correct in saying that I can use older FD mount lenses on my Canon EOS 50D or my EOS Elan II which both use the EF mount? And logically, they will only be fully manual?
    One of my uncles is offering to give me some old gear and there are three old FD lenses among the "stuff"... a 24mm, a 50 mm, and a 200mm.
  2. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    To be honest, I would not bother using the FD lens on my Canon digital unless the lens is a super nice lens to begin with. If I get nice lens such as the 200mm f/1.8 or 30mm f/2.8 FD lens, I do not mind get an adapter for it.
    Focus wise, it will be manual. But some of the adapter I saw said it has focus confirm.
  3. enzodm
    enzodm No longer a newbie, moving up!
    Sep 5, 2010
    1,509
    118
    Italy
    While other old lenses can be used with a straight, lensless adapter on EOS, due to registration distance FD needs an optical adapter to focus at infinity, so quality will degrade, and also focal length and aperture will change slightly (the adapter acts as a short teleconverter). Indeed they exist, including the expensive original Canon adapter sold when they switched from FD (1.26x focal length, -2/3 stops).
    It might be more convenient to buy an used mirrorless -any kind- where you could use a lensless adapter.
  4. Big Mike
    Dec 16, 2003
    33,864
    1,822
    Edmonton
    FD lenses are not compatible with EOS cameras, the mount is different.
    As mentioned, you can use an adapter, but that's not a great solution because a glassless adapter limits your focus range and one with glass will reduce the image quality you are used to with EF lenses.
    • Like Like x 1
