Few car shots.
Discussion in 'General Gallery' started by Bombers, Jul 8, 2010.
  1. Bombers
    Bombers TPF Noob!
    Jul 8, 2010
    53
    Illinois
    Also an amateur DSLR user so take it easy as this is my first post also.
    [​IMG]
    [​IMG]
    [​IMG]
  2. Bombers
    Bombers TPF Noob!
    Jul 8, 2010
    53
    Illinois
    [​IMG][​IMG]
  3. supraman215
    supraman215 TPF Noob!
    Oct 25, 2006
    979
    12
    Philadelphia
    #1 the composition is akward.
    #2 heavily under exposed.
    #3 Out of focus and the angle is also akward
    #4 needs a little more room to the left
    #5 needs a little more room to the left looks cramped. Also the guy is distracting.
    Keep working at it.
  4. Bombers
    Bombers TPF Noob!
    Jul 8, 2010
    53
    Illinois
    Thanks for the feed back supraman. I got a few more i've been messing with adding effects to and so forth. I have a few more i'll hopefully put up in the morning aswel.
    I know this one is a little bit weird..
    [​IMG]
    [​IMG]
    [​IMG]
  5. Bombers
    Bombers TPF Noob!
    Jul 8, 2010
    53
    Illinois
    Not many crits.. surprising.. I thought this would have gotten a better response but for those of you who actually do look through here I have a few more i'll post. [​IMG]
    [​IMG]
    [​IMG]
  6. supraman215
    Oct 25, 2006
    979
    12
    Philadelphia
    I would use the PP to add motion, maybe with motion blur on a masked area. Or sharpness. I'm not digging the coloring in 4 5 6 of the new set. and the softness added in #1 of the new set doesn't seem to fit with car photos.
  7. Bombers
    Bombers TPF Noob!
    Jul 8, 2010
    53
    Illinois
    The only thing I did to #5 was lighten it up a little bit because it was underexposed. And thanks for the c&c once again i'll keep these suggestions in mind for the next batch I put up.
  8. mar1u5
    mar1u5 TPF Noob!
    Feb 5, 2009
    640
    4
    oslo, norway
    Nr.1 Is ok. Would have been even better if you'd have the whole front of the car in the picture and cropped a bit off the top of the picture imho.
    Nr.2 If you want to do nighttime photography, forget about the flash and use a tripod and a long shutter instead. Unless you got several flashes, umbrella's and really know what you're doing with flashes ;)
    Nr.6 Would have worked much better if you had an 85mm f1.4 and shot it wide open with focus on the door. The "effect" really didn't work too well :)
    Nr.9 The coloring suggest vintage photo to me, and the subject is modern. I'd go totally black/white or color with that one. Good angle, but cut it a bit close to the front of the car.
