File Formats...
Discussion in 'Photography Beginners' Forum' started by BuS_RiDeR, May 9, 2010.
  1. BuS_RiDeR
    BuS_RiDeR No longer a newbie, moving up!
    Oct 29, 2009
    2,356
    83
    Riverview, New Brunswick, Canada.
    I am a computer technician... I know a lot about computer hardware and networking... But I fall short when it comes to some types of software.
    Now, I understand that RAW is one of the most favored ways to shoot/store images.
    I currently shoot in RAW and save the edits as JPEG...
    However, I was curious; what is the preferred file type to use?
    Obviously, JPEG is popular... But I've heard several comments about PNG or TIFF as well. Is there another file format that is better?
  2. reznap
    reznap No longer a newbie, moving up!
    Feb 2, 2010
    2,410
    64
    Ohio
    I like to shoot in RAW and save in 16-bit TIF. There's no such thing as a 16-bit JPG. The 16-bit color space is much better for editing purposes. Also you can save a TIF without compressing the image.
  3. Flash Harry
    Flash Harry No longer a newbie, moving up!
    Jun 26, 2006
    1,965
    14
    Durham, UK
    psd for saving layered files and non destructive editing and tiffs from converted psd's, jpeg only for printing is my preferred workflow. H
  4. I am Ivar
    I am Ivar TPF Noob!
    May 8, 2010
    30
    Delft, the netherlands
    Here's my structure:
    <dir> contains all raw files
    <dir/_jpeg> (if needed) contains all the raws converted to small jpegs to create a gallery for the client to pick the images from
    <dir/_final> contains all psds and jpeg exports of the edited images
    And depending on the needs of the client, the jpegs can also be tiffs :)
  5. D-B-J
    D-B-J Been spending a lot of time on here!
    Apr 13, 2010
    9,027
    2,172
    i also shoot in raw, then save as a jpeg.
  6. mtfd635
    mtfd635 TPF Noob!
    Oct 6, 2009
    87
    Live in NJ, work in NYC
    I shoot in jpg unless it's a sunset or floral shot that may end up as a 'fine art' (large) print
    a difficult shot or large print shot are done in raw/jpg.
    My day to day is construction documentary - large jpg are sufficient but an occasional raw worked n saved as tiff for special purpose (LARGE) print is needed.
    Up to your style and needs. Each has pro & con.
    Better to shoot big (raw) if you have time n memory, you can always downsize, but lil jpg's can't make a sofa size print
  7. KmH
    Apr 9, 2009
    40,732
    5,587
    Iowa
    Excluding my sports action images, I capture images as RAW data files (T&I sports shots included). RAW edits are saved in embedded .XMP files.
    Further Photoshop edits are saved as layered .PSD files with a copy saved as a layered TIFF only if required by the client.
    Nothing gets converted to an 8-bit color depth (.JPG) until all 16-bit color depth options have been exhausted, which usually means when the image is converted for computer/web use or as a print.
    I only use PNG for graphics files, never for photographic image files.
  8. BuS_RiDeR
    Oct 29, 2009
    2,356
    83
    Thanks for the input folks. I appreciate it. :)
  9. Vinny
    Vinny TPF Noob!
    Mar 14, 2010
    667
    New Jersey
    Since you are using GIMP check to see if you are working/saving in 16 bit. I believe GIMP mostly uses 8 bit with some 16 bit manipulation. From what I've read the next version will be totally 16 bit.
  10. magkelly
    magkelly TPF Noob!
    May 5, 2010
    270
    USA
    I usually shoot in jpg or raw depending upon use. I often shoot jpg if it's just a few quick pics of something I need to show my friends online or to sell something, but for most serious shooting I've already gone to shooting raw even though it's more work given the few CF cards I own are pretty space limited. Saving depends upon what I am using the shots for. I save raw, psd for images with layers or tiff. I use jpg now only if I am going to use it on a web page or send an image via email.
    Rule of thumb since I've started using Camera Raw a bit more, if I think I want to edit it some more I save it in raw. If I think I'm done then I usually will save a tiff and a jpeg as well as the raw just to have extra versions I might need for other uses. Shot raw saved to corrected raw is a must because it's a non-destructive file, but since to use a pic for desktop publishing or web work I usually need tiff's and jpegs anyway having all three on the disc I save them to still comes in handy.
  11. Romphotog
    Romphotog TPF Noob!
    Jan 24, 2008
    108
    On planet Earth.
    Preferred as in doing what? JPG's drawback is that the quality degrades when you save again. Unlike with a txt or a doc file, whose quality remains same, jpg files quality worsens with each save. They have a quality meter so keep above 90%.
    I just zip original jpgs, and save into bak folder, edit and save at 90%.
