Filesize too big
Discussion in 'Graphics Programs and Photo Gallery' started by pongerts, Jun 28, 2009.
  1. pongerts
    pongerts TPF Noob!
    Jul 24, 2008
    89
    AUH, UAE
    Good day once again to the folks of TPF!
    Ei! I've got a questions once again.
    Whenever I edit a photo in photoshop and get it read for printing,
    I always end up with a huge file! And by huge I mean something around
    300MB of a file! And that's only for a picture of around 1.5m x 1.25m and
    a resolution of +/- 200dpi. And there was another time when I edited a backdrop for printing, I ended up to around 600MB for a 2.5m x 1.75m/300dpi image.
    Is this just right? Does converting a picture (or a layer) into a smart object contribute to this enormous size?
    Thanks again! I know we've got a lot of folks here who are very knowledgeable on these kinds of stuff!
  2. manaheim
    manaheim Jedi Bunnywabbit Staff Member Supporting Member
    Sep 2, 2005
    14,394
    3,262
    What colorspace and bitrate are you working in? Both of those could affect this and wouldn't surprise me at all if you had a pic that size. Some of my bigger ones are 200+.
  3. musicaleCA
    musicaleCA TPF Noob!
    May 23, 2009
    2,303
    Vancouver, BC
    Annnd, file format. TIFFs are gigantic, if you keep layers. If you toss the layers and apply some compression, TIFFs are far less scary.
  4. pongerts
    pongerts TPF Noob!
    Jul 24, 2008
    89
    AUH, UAE
    I believe that it's an 8bit image.
    and I save them as jpgs.
    But is it just normal to have that range of files when sending them out to print?
  5. Peano
    Peano TPF Noob!
    Dec 21, 2008
    358
    22
    Washington, DC
    I'm not sure I'm understanding you: You end up with jpegs that are 300 MB? What are the pixel dimensions (W x H) of these images?
  6. Dwig
    Dwig TPF Noob!
    Mar 11, 2009
    1,261
    Key West FL
    ONLY for a 1.5m x 1.25m x 200dpi image!!
    What you are seeing is normal. These are very large images at high resoluiton. (for the math crippled out there, this a 58"x47"image that at 200ppi works out to around 11800 x 9450 pixels). Even at 8bpp that's going to be a large file if saved as a TIFF or PSD. Add to that multiple layers, and the file can get huge.
    Any layer with bitmap data, actual image or layer mask, adds a lot of bulk to the file. Adjustment Layers can be compact, but if you add a Layer Mask they aren't. Ond Adjustment Layer with a mask adds about 30-35% to the file size. Adding a full color background leaving two layers can easily double the file size.
  7. Error
    Error TPF Noob!
    Jul 6, 2009
    75
    Open your image in adobe photoshop then save as to a 'new filename' but make sure to adjust the image options quality such as Low, Medium, High, & Maximum. By that, your image sizes will reduce to a smaller bytes. Doesn't matter whatever dpi that you have as long as you save it in a smaller quality like this...
    [​IMG]
  8. Big Mike
    Dec 16, 2003
    33,852
    1,817
    Edmonton
    But you don't want to use 'low' (or even medium) when sending the files for printing....do you?
    I've found that you can drastically reduce the file size by saving at around 90% quality (11 out of 12...one notch down). I usually prefer to save my files for print at 100%...but for larger files, the difference in file size might be worth it.
    You might consider reducing the resolution. 200 PPI might be more than you need for a print that large. Remember to take into account the normal viewing distance for something that size. It's probably something like 5-10m...and at that distance, you probably can't tell the difference between 200 PPI and 150 PPI.
  9. Error
    Error TPF Noob!
    Jul 6, 2009
    75
    Yes I play around with 10-12 if the photos will be posted at any website forum but If you need a good photo quality when you print it... make sure that the resolution of your image will set to 300 pixel/inch for 8x10" print size & for 4x6 print size a 100 pixel/inch is enough to get a good quality of your images. I used Genuine Fractals Express plug-in to adjust or resize my photos in able not to destroy the image quality of my work.
file too large to print
how to print a photo that is too big
how to print pictures that are too large
if the image is too big for print, what should we do
photo file size too large
photo size too large
photos too big to print
picture file size too big for facebook
picture is too large to print
picture too large for 8x10
