Film developing solutions/agents
Discussion in 'Film Discussion and Q & A' started by ultimadrift, Jun 18, 2011.
  1. ultimadrift
    ultimadrift TPF Noob!
    Apr 17, 2011
    128
    5
    Sacramento, CA
    I've been looking online for hours and still not able to get a direct straight forward answer on which solutions/agents to buy? I know that I need a developer, stop bath, and fixer. What are all the different numbers mean with C-41 and E-6 etc? Do they differ from different types of film? I'm only planning to do B&W film. Thanks for answering my questions.
  2. ultimadrift
    Apr 17, 2011
    128
    5
    Sacramento, CA
    So I took a snapshot of my shopping cart for a simple B&W film developing kit. Anything else I should add to this before I hit buy?
    [​IMG]
  3. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    c-41 and e 6 chemistry is for color processing.
    The problem your having with getting a direct answer is we all have our favorites and it is unlikely everyone will agree.
    Film developer. HC-110 used as a one shot developer
    Kodak or Ilford stop bath
    Ilford fixer
    LPN wetting agent.
    LPD paper developer
    Stop bath can be used for both film and paper, but at different ratios same with the ilford fixer.
    I am not fan of the accordian style containers, they are a pain IMHO.
    You don't need a changing bag, a darkroom, think bathroom without windows , will do
    You will need more than one graduate, and frankly you can find all sorts of items to use at the dollar store. plastic funnels can also be found at the dollar store or a car parts store for a lot less money than $5,
    Check out Ilford's website for great pdf's on equipment and processes.
    • Like Like x 1
  4. Helen B
    Helen B TPF Noob!
    Sep 16, 2007
    3,296
    465
    Hell's Kitchen, New York
    You might also want a thermometer.
    Best,
    Helen
  5. ultimadrift
    Apr 17, 2011
    128
    5
    Sacramento, CA
    Thanks for the advice. So are the one shot developers better or worse than the ones you can use again? Also wetting agents are usually suppose to help it not get spots on the film right?
  6. dxqcanada
    dxqcanada Been spending a lot of time on here!
    Dec 4, 2008
    5,983
    852
    Woodbridge, Ontario, Canada
    One shot is good if you are not continually developing ... I have never used a replenishable developer.
    I like Rodinal or Ilfosol S developer, and I am not fussy about the Fix or Stop bath (though I tend to use Ilford chemistry for that)
    I used a wetting agent to reduce water drying marks.
  7. dxqcanada
    Dec 4, 2008
    5,983
    852
    Film squeegee
    Film clips (or cloths hanger clips).
    Bottle opener
    You can glance at Ilfords chemistry for B&W film and paper: Welcome to ILFORD PHOTO
  8. Helen B
    Helen B TPF Noob!
    Sep 16, 2007
    3,296
    465
    There are some reusable developers, like Diafine, that are very easy to use but one-shot developers tend to give more consistent results, more easily. Some developers can be used one-shot when diluted, or re-used undiluted with slight differences in characteristics between the two methods. The most well known of these are probably D-76, ID-11 and XTOL. Diafine is a really foolproof developer, but it does affect film speed.
    HC-110 is a good all-round economical one-shot developer. Instead of the fancy measuring syringe many people use a normal syringe from the drug store. It's not a bad idea to have different measuring cylinders etc for developer and fixer.
    Wetting agent is useful, and so is a final rinse in deionised or distilled water. I don't usually bother with wetting agent and just do the final rinse in deionised water. Wetting agent is, however, very cheap. It's like stop bath - you don't absolutely need it, but it is very cheap.
    I prefer rapid alkaline or neutral fixer for fast fixing and fast washing. Depends on what you can get. You can use plain hypo from a pool store.
    Personally I would not use a film squeegee, but it's a matter of opinion.
    Best,
    Helen
  9. SoonerBJJ
    SoonerBJJ No longer a newbie, moving up!
    Oct 5, 2009
    438
    50
    Texas
    Good advice above. I use Rodinal and HC110 as one shot developers.
developing agent in photography
film developing solution
photo developing solution
replenishable developer definition
replenishable developer in photography
replenishable developer photography
solution for developing film
what is a replenishable developer
what is replenishable developer
