film latttitude and cross processing
Discussion in 'Alternative Techniques & Photo Gallery' started by knowstial, Jun 11, 2007.
  1. knowstial
    knowstial TPF Noob!
    Jun 11, 2007
    Ohio
    I was wondering if anyone knew how different film lattitudes will affect cross processing specifically in negative rolls. can someone give examples of film stock and results? I will also post on darkroom.
  2. Hertz van Rental
    Hertz van Rental We're supposed to post photos?
    Nov 8, 2004
    16,738
    46
    Where am I now?
    Cross-processing and film latitude are completely unconnected.
    Cross-processing is a method used with colour film. You process transparency film as if it were negative, or process neg film as if it were transparency. The two methods of development use different colour couplers so the resultant colours are not what you would naturally expect.
    Film latitude is to do with the exposure range a film is capable of dealing with.
    If you plot a graph for a film's response to light - density against exposure - you find there are two points: Dmax and Dmin. That is, the minimum density that the film will record and the maximum. The exposure range equivalent between these two points is the film latitude.
    So to answer your question: latitude has absolutely no effect on cross processing.
  3. mysteryscribe
    mysteryscribe TPF Noob!
    Feb 1, 2006
    6,071
    in the middle of north carolina
    Not to mention I have never been able to figure out what would be on the film EXACTLY anyway. In either case. I need one of those charts to carry with me.
