film scanner
Discussion in 'Beyond the Basics' started by fightheheathens, Jun 4, 2007.
  1. fightheheathens
    fightheheathens TPF Noob!
    Aug 1, 2005
    1,011
    Berkeley
    so im looking into getting a used film scanner off E-bay
    my price range is 100-200 bucks (ideally i spend 150)
    i dont need anything fancy and my main use for the scanner would be to
    scan all my negs to use as a sort of contact sheet. I develope my own B&W and i do have access to a dark room, but i would rather spent my hours in there actually printing pictures rather then contact sheets to see what my pics look like. (it does cost me to use said darkroom)
    I would also use the scans to post here.
    I would use it to scan slides to and other color films.
    Ive been looking on e-bay and a scanner that comes up often (for around 150) is the Nikon LS-2000. I dont know much about scanners. I've looked stuff up and i understand that whole ICE thing (to get rid of dust) and i get the whole resolution thing but im a little confused on the color depth, IE 8 bit vs 16 vs 32 etc. Anyway, what are good scanners in that price range (remember im looking used) and what are things to look for in a scanner.
    also what are some scanners to avoid.
    Im not looking for something super good, im not going to print from the scans (ill print from the actual negs) but i also dont want a piece that im going to be frustrated with
    help would be cool
    thanks
  2. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Are dedicated film scanners even needed these days? We just bought a new canon all round scanner. It had plates for mounting film and slides which is painless to do, and the photos came out spectacular by the standards of our last scanner. And this new one wasn't even all that expensive.
  3. mysteryscribe
    mysteryscribe TPF Noob!
    Feb 1, 2006
    6,071
    in the middle of north carolina
    Well I bought a new flat bed scanner with a high dpi like 4800 or something like that. It scans 35mm but i bought it to scan med and large format negs. I did the 35mm and was just okay I thought, so I bought an old super cheap dedicated one on ebay. I was amazed how much better the lower resolution scans looked.
    But just to check it out have the drug store make you a couple of scans on their film scanner then check them against you table top. If they are as good you might be right. That was just my opinion, but then I now own both scanners and one more I scan paper negative with. Like to keep the new flatbed for film only.
  4. Alpha
    Alpha Troll Extraordinaire
    Mar 15, 2005
    5,454
    41
    San Francisco
    The LS2000 is built mostly for slide scanning, though of course it is capable of negative scanning as well. It's a pretty decent scanner.
  5. mysteryscribe
    Feb 1, 2006
    6,071
    Ive looked into that but I had really good luck with the plustec I think if I go back to shooting weddings I'm going to get their 7200 dpi film scanner. It seems to be pretty well thought of.
  6. fightheheathens
    Aug 1, 2005
    1,011
    Berkeley
    thanks for the info so far. I usually only shoot color in slide film and then B&W, also B&W infrared
    I had access to some nikon coolscans in college, i dont remember exactly which ones they were, but they were in the price range of 1200 usd and they were freaken sweet.
105 mm film scanner
105mm film scanners
basics film scanner
film scanner
film scanners in berkeley
table top , film scanners
