Film Scanners
Discussion in 'The Darkroom' started by mctb, May 9, 2016.
  1. limr
    limr Moderator Staff Member Supporting Member
    Jun 9, 2013
    16,905
    9,061
    It also depends on size of the negative and if it's color or black and white. The longest I'd say is about half an hour for a full tray of color 35mm (12 frames). 120 goes faster simply because you are scanning fewer frames - the holders are only big enough for 3 frames of 6x6 or 4 frames of 6x4.5.
  2. mctb
    mctb TPF Noob!
    Apr 28, 2016
    40
    12
    Your CanoScan. It's either that or the Epson.
  3. mctb
    mctb TPF Noob!
    Apr 28, 2016
    40
    12
    That's not bad really. The way it was being mentioned, I was expecting longer. I imagine the DSLR method might be a quicker capture but the post processing difference might even things up a bit.
  4. 480sparky
    480sparky Chief Free Electron Relocator Supporting Member
    Mar 8, 2011
    22,744
    8,137
    Iowa
    Mine is a PlusTek.
  5. gsgary
    gsgary Been spending a lot of time on here!
    Oct 31, 2008
    16,144
    2,945
    Chesterfield UK
    I've had big prints no problem from my Epson V500 and Plustek 7500
    Sent from my SM-G903F using Tapatalk
  6. table1349
    table1349 Been spending a lot of time on here!
    Sep 9, 2006
    4
    One thing I believe has not been mentioned is software. OEM software with any device is generally good but not the best. Personally I use Silverfast with my Epson V600.
  7. gsgary
    Oct 31, 2008
    16,144
    2,945
    Chesterfield UK
    I use Vuescan
  8. table1349
    Sep 9, 2006
    4
    We did too. It's also a good piece of software. Wife still does with an older HP scanner with document feeder. I switched when I fell into a large negative and positive archive job with boxes full of negatives and old photos being organized for a digitized family tree.
    The archival feature in Silverfast saved me some time.
