filter conversion
Discussion in 'Beyond the Basics' started by whardman, Jun 2, 2006.
  1. whardman
    whardman TPF Noob!
    May 26, 2006
    111
    Cincinnati, Ohio
  2. Johnboy2978
    Johnboy2978 No longer a newbie, moving up!
    Oct 21, 2004
    1,797
    30
    Southwest Virginia
    If your lens accepts a 55mm filter and your filter is 49mm then you would need this (step down filter):
    http://www.bhphotovideo.com/bnh/con...920&is=REG&addedTroughType=categoryNavigation
    If your lens accepts a 49mm filter and your filter is 55mm then you would need this (step up filter):
    http://www.bhphotovideo.com/bnh/con...636&is=REG&addedTroughType=categoryNavigation
    There are probably cheaper ones...these are B+W. Ideally, you want your filters to be as large as your largest lens and use the step up filter rings to eliminate vignetting.
