filter questions
Discussion in 'Beyond the Basics' started by goodoneian, Apr 10, 2008.
  1. goodoneian
    goodoneian TPF Noob!
    Apr 6, 2008
    528
    temecula, ca
    hey, where is a good place to buy filters? i don't mean the screw in kind, but the ones that are a square of glass that mount on the end of the lens such as ND filters. sorry i don't know any of these by their "technical" names you could say. i've seen some on ritzcamera.com, but i'm sure there is more out there than that, and i'm wondering what you guys would recommend. thanks
  2. rjackjames
    rjackjames TPF Noob!
    Mar 11, 2008
    988
    South Korea
  3. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
  4. Village Idiot
    Mar 20, 2008
    7,274
    406
    www.hvstar.net
    Pretty much the lowest prices I've seen from a legit site. They have B+W filters for less $20 and $30 less than B&H
  5. Steph
    Steph No longer a newbie, moving up!
    Oct 18, 2006
    1,314
    Steventon, Oxfordshire, UK
    The only problem with those is that their neutral density filters are not really neutral and sometimes give a purple cast to skies!
  6. Dutchboy
    Dutchboy TPF Noob!
    Apr 6, 2008
    57
    Toronto, Canada
    The Cokin holder is great, have been using it for years. It can also hold a large circular polarizing filter. I highly recommend it.
    While on the subject of filters, should I remove my UV/haze filter before screwing the Cokin holder on? I've heard stacking filters may not be a good idea sometimes. For that matter, is there any real reason to have a UV filter as opposed to a clear glass protective plate (or nothing)? I've heard mixed opinions about UV filters.
  7. Socrates
    Socrates TPF Noob!
    Jan 28, 2008
    1,183
    Exit #5
    A filter ALWAYS reduces the quality of the image (the only question is the degree of quality reduction) and a filter iis ALWAYS a bad idea unless you have a good reason to use it. It follows then that multiple filters reduce the quality of the image more than a single filter does. Stacking can also cause vignetting (not in the case of Cokin) because the multiple filter mounts cause the lens to look through a tunnel.
    I buy only absolute top-of-the-line filters because I want to minimize the loss in quality and maximize the benefit.
    Regarding UV... If you already have a UV filter, it's fine as a lens protector but, if you're purchasing a new filter for that purpose, clear glass is less expensive. However, as I indicated above, the filter quality is paramount.
  8. Dutchboy
    Dutchboy TPF Noob!
    Apr 6, 2008
    57
    Toronto, Canada
    So would you say that UV filters will improve the image then (provided it's a near-top of the line one)?
    Thanks for the info Socrates.
  9. goodoneian
    Apr 6, 2008
    528
    temecula, ca
  10. Socrates
    Socrates TPF Noob!
    Jan 28, 2008
    1,183
    Exit #5
    No. It won't "improve the image" UNLESS your intention is to remove ultra-violet rays. By the way, UV rays are present in sunlight and they adversly affect film. I don't know if they affect digital sensors. On the flip side, buying a high quality one means that it won't degrade your image as much as a cheap one will.
  11. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Quality wise I'm not to sure. I have heard about their purple cast problems. That said I don't know any other square filters than the Cokin P system.
  12. Helen B
    Helen B TPF Noob!
    Sep 16, 2007
    3,296
    465
    Hell's Kitchen, New York
    Singh-Ray, Schneider/B+W, Heliopan, Formatt, Lee, Harrison and Harrison, Tiffen and probably one or two more companies I'll remember later.
    I use mostly Schneider, with a few B+W and Lee ones. They are very common in the movies.
    Best,
    Helen
