Filter step down/up adapters
Discussion in 'Photography Equipment & Products' started by reshp1, Apr 5, 2007.
  1. reshp1
    reshp1 TPF Noob!
    Mar 26, 2007
    58
    I'm looking to get a 3.0 ND filter so I can do long exposures in daylight, but unfortunately I have two lenses of different sizes and soon will add a third of yet a different size. Does anyone use one of these adapters? How well does it work. Also, how much of a set up is reasonable, i.e. can I use a 52mm filter on a 72mm lens? I suppose it depends on the lens and the zoom setting, but what's a good rule of thumb? The larger lens of the two-72mm is a long focal length zoom and if I needed to use the wider angle end of it, I would probably use the 52mm lens, does this buy me more step up room?
  2. Steph
    Steph No longer a newbie, moving up!
    Oct 18, 2006
    1,314
    Steventon, Oxfordshire, UK
    Buy the filter for the lens with the larger diameter (72 mm) and then stepdown rings for your over lens(es). If you use a filter smaller than the diameter or your lens you are likely to get vignetting.
  3. reshp1
    reshp1 TPF Noob!
    Mar 26, 2007
    58
    Oh yeah, sorry I forgot to mention, I would much rather get the smaller 52mm filter since it's less than half as much as the 72mm version. Maybe I'll try putting a piece of paper over the edge of the larger lense and seeing if there's a visible difference.
  4. dinodan
    dinodan TPF Noob!
    Jan 21, 2007
    417
    Charleston, South Carolina, USA
    I would be VERY surprised if that works out.
  5. zioneffect564
    zioneffect564 TPF Noob!
    Feb 24, 2007
    309
    Dallas/Ft. Worth, Texas
    Me too... and im pretty sure that it will be visible
  6. jamescell
    jamescell TPF Noob!
    Mar 25, 2007
    60
    Do they make rings that step down?
  7. astrostu
    astrostu Guest
    If not vignetting, then you will at least get significantly less light through the lens - 52.2% to be more accurate (the area of a 52 mm aperture divided by the area of a 72 mm aperture).
    Yes.
  8. xfloggingkylex
    xfloggingkylex TPF Noob!
    May 5, 2006
    1,292
    Frederick, MD
    they do make step down rings, but its harder to find because no company concerned with quality is going to do that to its customers. if you use a 72 mm lens with even a 68mm filter chances are you'll get vignetting. With a 52 mm filter on it, wow just be ready to crop your pictures tightly in the center (pretty much eliminating the idea of a wide angle).
    Of course you dont want to spend the money for the 72, but please, do it right the first time and buy the filter for the largest lens size you'll use a filter on, and you will save yourself money in the long run by not having to buy the 52, realize it doesnt work on the 72 and buying the 72 anyways.
  9. fmw
    fmw No longer a newbie, moving up!
    Sep 30, 2006
    3,343
    396
    Whether you can mount a smaller filter on a larger front element depends on the focal length of the lens and its maximum aperture. Sometimes it will work with slow telephoto lenses but not often. Basically, you need to heed the advice above. Get the big filter and step down to the smaller lenses.
  10. reshp1
    reshp1 TPF Noob!
    Mar 26, 2007
    58
    Alright, I guess the 72mm it is. Thanks for the input
any difference step down or up filter adapter
explain step down adapters
for camera lens ring adapter, explain step up and step down
how does a step down filter work
how filter step down work
lifetouch.com/backgrounds
short skirt
using a step down filter adapter
what do i need stepup or stepdown adapters for cameras
why to use step down filter adapter
