Filter Thread size.
Discussion in 'Photography Beginners' Forum' started by jdjd1118, Jan 13, 2008.
  1. jdjd1118
    jdjd1118 TPF Noob!
    Dec 19, 2007
    191
    New Hampshire
    I'm thinking about buying a wide angle lens or telephoto lens for my DSC-H2. The original filter thread size is 58mm. Should the lenses I buy have a greater filter size at the front, or could I just go with one that also has 58mm? I don't want to end up with any "tunnel effect". Thanks
  2. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    different focal lengths, have different requirements for filter sizes. It is very doubtful that you will find a wide angle lens and a long focal lenth lens with the same filter size.
  3. jdjd1118
    jdjd1118 TPF Noob!
    Dec 19, 2007
    191
    New Hampshire
    Thanks, I saw some that had the 58mm size, but I'm probably going to go with one with a bigger thread size.
  4. Tighearnach
    Tighearnach TPF Noob!
    Oct 26, 2007
    224
    Hi.
    Im pretty sure you can buy the filter for the bigger thread size and get a type of adaptor that helps it fit onto any threads smaller than it. Have not done this myself but from what ive read on this site it does not affect the picture quality.
    I wouldnt let a filter size issue influence what lens i bought. Buy the best glass you can afford and then worry about the filters.....
  5. ann
    May 14, 2007
    4,263
    189
    you can buy a step up ring or a step down ring and go either way.
    and i agree with the other post.buy the lens that is going to give you the best results and not which has the same filter size. Filters in within the big picture are cheap.
filter thread size for h2 lenses
picture of thread filter
