filters and varying lens sizes
Discussion in 'Beyond the Basics' started by SierraBravo, Jan 18, 2008.
  1. SierraBravo
    SierraBravo TPF Noob!
    Jan 10, 2008
    13
    I have a 40D and three lenses in my bag (so far :sexywink:) - the kit lens (17-85mm f4-5.6), a "magic drainpipe" (80-200mm f2.8) and a 50mm f1.8. The three take filter sizes of 67mm, 72mm and 52mm respectively.
    I'm kind of hoping to economize on filters a bit and use step up or step down rings. As I am unfamiliar with these for the most part, which do you think would work best, buying smaller filters or larger filters with this range of lenses? I'm a bit lost here. Only filter I have thus far is a 67mm UV. I would rather buy one GREAT circ polarizer, for example, than economize and buy more than 1, if I could...
    Thanks in advance. New to all this stuff and a bit confused, as usual. :)
    Sarah
  2. HASHASHIN
    HASHASHIN TPF Noob!
    Mar 1, 2007
    414
    NYC
    it's better to go big and step down.
  3. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    Yes, it's much better to get a big filter and step down.
    If you do it the other way, and use small filters, you will get vignetting or worse. Imagine a 52mm filter on a lens with a 72mm front :er:
  4. SierraBravo
    Jan 10, 2008
    13
    hey, thanks! I was thinking that might be the case. 72mm filters it is! Now to find the perfect circular polarizer...
  5. Sideburns
    Sideburns TPF Noob!
    Aug 14, 2007
    2,796
    Windsor, Ontario
    B+W MRC.
  6. SierraBravo
    Jan 10, 2008
    13
    Sideburns, that is what I have heard.
