Filters for Real Estate Photography
Discussion in 'Photography Beginners' Forum' started by ChrisF79, Feb 8, 2008.
  1. ChrisF79
    ChrisF79 TPF Noob!
    Feb 6, 2008
    49
    Greetings:
    I am going to be shooting a lot of real estate (both inside and out) in South Florida. What filters do you recommend?
    The one thing I've noticed is that the best pictures in magazines like http://www.luxuryportfolio.com/property/old_naples/significant_beachfront_residence.cfm have very bright blues and greens to highlight landscaping or the gulf of mexico.
    Any tips on filters would be very helpful.
    Thanks in advance!
  2. Big Mike
    Dec 16, 2003
    33,853
    1,818
    Edmonton
    For outdoor shots in sunny conditions, I would recommend a circular polarizing filter...but that's it.
    Good technique will take you a lot farther than filters.
  3. domromer
    domromer TPF Noob!
    Aug 11, 2007
    878
    Eugene, Oregon
    Real Estate photography is what I do for a living. All I use is a polarizer. Otherwise I take care of everything in photoshop.
    Obviously bring a tripod, a remote is nice as well. Do you have access to a light kit? Those can be very helpful sometimes.
    A wide angle prime would be very nice to have as well. I can't really afford one but my pics are in local real estate mags and not New Home Digest!
  4. itoncool
    itoncool TPF Noob!
    Nov 27, 2006
    131
    Circular Polarizer, you'll find it really helpful in bright daylight especially on reflective surface.
  5. ChrisF79
    ChrisF79 TPF Noob!
    Feb 6, 2008
    49
    Thanks for the tips. Circular polarizers really do look nice. Can you tell me what this means though? "77 mm Circular Polarizer Multi-Coated (MC) Glass Filter"
    I don't know what the different sizes are and then this one is multi-coated and another one says linear.
    Thanks again for the help!
  6. Emerana
    Emerana TPF Noob!
    Jan 2, 2008
    857
    Houston, Texas
    you want cicular. buy a nicer one, it makes a difference. the size of your lens is on the lens somewhere. 77mm is fairly large...if you need help you can take your lens in to a camera store and ask them to show you. also if you have more then one lens, get the polarizer to fit the largest lens and then step up rings to fit the other one. You might also want to get a lens hood if you dont have them.
  7. KVB1085
    KVB1085 TPF Noob!
    Jan 30, 2008
    102
    Marietta Ga
    i'm doing some real estate shots myself this weekend hopefully they will come out well... gl...
  8. Big Mike
    Dec 16, 2003
    33,853
    1,818
    Edmonton
    Linear polarizers are for older cameras...newer (auto focus) cameras will need a circular polarizer.
    I don't know all the codes and names that they use...but it is certainly helpful if the filters have high quality coatings to reduce things like flare.
    Putting a filter in front of your lens, means that the light has more glass to pass though, so if you are concerned about image quality, you will want to use high quality filters. There is little point in buying a $1000 lens, only to put a $10 filter on the front.
  9. ChrisF79
    ChrisF79 TPF Noob!
    Feb 6, 2008
    49
  10. cameramike
    cameramike TPF Noob!
    Sep 4, 2007
    875
    NJ
    is your lens 77mm filter size? (look at the front of it and it will say) or tell us your lens. looks like a good one.
  11. AlexParlett
    AlexParlett TPF Noob!
    Jan 31, 2008
    49
    Oxford, UK
    The 77mm, refers to diameter of the thread on the end of the lens that can be used to adding circular screw on filters.
  12. ChrisF79
    ChrisF79 TPF Noob!
    Feb 6, 2008
    49
    I haven't purchased my camera yet but I'm going to buy the filter at the same time. There's that same filter in a number of sizes so I'm more or less just asking about the quality of that particular one--assuming I can get it in the size I need.
filters for real estate photography
filters real estate photography
Photo filters for listing pictures
polarizing filter for real estate photography
real estate photo filter
real estate photo filters
real estate photography filter
real estate photography filters
real estate picture filter
what is the best filter for real estate photography
